Keeps turning off
We had someone move in downstairs from me and 2 weeks later the tv in my sons room began to just turn itself off. Then 3 weeks after that the Tv in my living room started doing the same thing. You tunr it on and it stays on for maybe 15-30 min and clicks off. This started after downstairs had their cable installed
    Problem Solver:
  • 9 Answers
FIRST all projection TV's have bulbs.
Some have filters either on the bulb cage or on the outside of tv or both. When the bulb gets too hot it will protect itself by shutting off - clean and make sure they have good airflow.
Unless your D/s buddy has infared power not heard of - it's probably not him.
Posted on May 20, 2009
I have a Harmon Kardon AVR146 receiver and the volume suddenly goes way up by itself, it began about 2 weeks ago and it getting worse. I changed the batteries in the remote thinking that would help bu
this is a bad overheated chip or chips the only thing you can do is when it does it again open it up with it unplugged see if a chip is very hot to the touch if you find one or two: heat sink them with an aluminium heat sink and thermal paste to keep them cool.
Dec 03, 2013 | Harman Kardon Audio Players & Recorders
We have a 50 inch panasonic plasma hd television we bought in 2007. The tv was great until 2 days after the extended warranty ran out (with Circuit City who, of course, is no longer in business anyway). ...
The main power supply regulator board fault. It will be best to replace the power board as card basis rather than trying to repair it. Because, in most cases repair work on this board will be a failure, especially to Plasma displays. If you wish to get more details visit the site linked here. It will help you to an extent, I beleve. http://electronicshelponline.blogspot.com/ Faults of many popular brand sets are given.
Mar 01, 2017 | Panasonic TC-P50G15 50 in. Plasma HDTV
I was playing my PS3 and moved it from my tv upstairs to my tv downstairs. After plugging my PS3 in my tv downstairs, on which it had worked just 1 week previously, my tv picked up no signal from my PS3....
Try this.
Plug your PS3 on either TV. Turn on the backswitch. When the red light in front is on, put your finger on the on/off button in front AND KEEP IT THERE. You will hear some beeps; don't worry about that. Keep your finger on the button until the front power light goes red again. This resets the PS3 video settings. Turn the PS3 on and the TV should pick up the signal.
Hope this helps. Keep us posted.
Jul 04, 2011 | Sony Playstation 3 (PS3) Console
The TV switches it self off
Sorry to here about your TV problems but it is almost imposable to help someone with technical problems if they don't list a product, model or P/N number.
Either-way, I would try moving the unit in an area where it has more breathing space if poss-able.
Also, is the unit in a air conditioned area or in a Damp basement or Florida room ?
I would also, go on line and see if Panasonic has any call backs on this unit.
This may be a feature which can be reset without to much trouble.
Next time please list the size & model #.
Jun 16, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
None working Polariod FLM 2601.
Hmm,
Might be a bad connection inside set, but might want to get the obvious stuff out of the way first.
1. Verify outlet is working by plugging something else into it.
2. Make sure the ac cord is pushed in all the way into tv. Might not be making good contact.
3. Double check to make sure tv doesn't have a power on/off switch. Some TVs have a power button and also a power switch somewhere on the bottom or back of set that might've been flipped off if there is one.
Apr 26, 2009 | Polaroid FLM-2601 Television
TV turns itself off
If you can solder i can help you fix it yourself ! On Deflection board there is 3 capacitors cp150 2200uf 16v if it is puffed up on top it is Bad other 2 220uf 35v cp114,cp120 they are green with gold writing on them Deflection board is First board to left on bottom/ board to right is SSB board this has your turners on it. Also CK second ribbon connector that connects from deflection to SSb board. Id say its Bad Capacitors on deflection board. Thats why set takes time to come back on it will finally get to where it will not come on.
Jan 05, 2009 | RCA R52WH73 Projection Television
Help!
You have a button stuck either on the set itself or on the remote. Stargazer
Aug 16, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv keeps turning itself off
you must contact service bycouse you need the asistance
May 25, 2007 | Toshiba MD20F51 20 in. TV/DVD Combo
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
TV keeps turning itself on and off, onto standby
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
