Question about Bose Companion 2 Series II Multimedia Speaker System (2-Piece)
Bose companion 2 left speaker does not work
Left speaker does not work
SOURCE: bose companion speaker stopped working!?
What happened to you is probably mere coincidence with your cousin's use of the headphones and this is throwing you off. I own the Bose Companions also and they stopped working as well. However, I traced the problem to the "wall wart" power supply. Not sure why but Bose is now using an interchangable plug on them. If you look at the power supply you will see a "PUSH" button. If you depress it the plug can slide out. When it is slid back in and locked in place the connection between the plug plate and the power supply is not a good one. Try fiddling with it. But even if the connection is not the culprit, something in the power supply is. I swapped another power supply with the same connector and spec's ( amps must be the same ) from another item and the speakers worked perfectly.
Posted on Dec 14, 2008
SOURCE: Bose COMPANION 2 Speaker case disassembly?
yes..the only solution is to pop the front panel with screwdriver...to do this more efficiently (without breaking the front panel) ...first insert the thin screwdriver in the gap in front lanel on side wall...and rotate the screw driver 90 degree..this will pop that side....repeat it on other sides too...i did it last night only.....
my problem was that when i dropped the speaker....its magnet fell down...and its no longer working...i am trying to find another broken bose speaker to replace mine...from e bay,,but no luck till now :(
Posted on Jan 26, 2009
DosHog
  • 168 Answers
SOURCE: Bose desktop speakers stopped working suddenly
Make sure that the power is plugged into both the wall or strip and the back of the speaker.
Posted on Jul 17, 2009
pandeyram1
  • 192 Answers
SOURCE: No sound is coming out of our Bose Companion 2
please check all the cables are inserted properly in his own place.
Posted on Apr 02, 2010
SOURCE: would like to know how to open speaker cabiant.
currently trouble shooting Bose Companion 2 computer speakers, no sound from speaker, would like to know how to open cabinet to see if wires are attached to speaker?
Posted on Jun 13, 2010
My Bose companion 20 right speaker will not work on my I pad
Plug a pair of earphones into the iPad to see if the problem is the speakers or the iPad. Once you have the piece that's not working correctly figured out, it's time to take it to the repair shop.
Jun 12, 2015 | Bose Companion 20 multimedia speaker...
Bose Companion 3 Series 2 Multimedia doesn't work.
Maybe a tranformer burnout, this is the most common cause, refer to a Bose service center
Jun 15, 2014 | Bose Companion 3 Series II Multimedia...
Bose Companion 2 speakers and Windows 7
Scan your computer with RadarSync so that it will detect which driver updates are needed. It will grab the drivers and update them.
David
Jun 26, 2013 | Bose Companion 2 Series II Multimedia...
My Bose Companion 3 coputer speakers are 2 years
i hav the same problem but all three shut off ,and i have to shut off and turn on again
Jul 29, 2010 | Bose Companion 3 Computer Speakers
Left speaker works but right speaker does not work gene.hall33@yahoo.com
Funny, this happened to me just 2 days ago, but I get no sound from the left speaker. Maybe they have all of them rigged to fail at a certain time.
Jul 08, 2010 | Bose Companion 2 Series II Multimedia...
Would like to know how to open speaker cabiant.Bose companion 2.
May 24, 2010 | Bose Companion 2 Computer Speakers
BOSE speakers won't work with my HP Pavilion Desktop......help!
try reinstalling the software for them then make sure your sound card drivers are installed properly
Aug 10, 2009 | Bose Companion II Computer Speakers
Not working on my hp
make sure there turned on or make sure it`s in the right AUX input
Apr 13, 2009 | Bose Companion 2 Series II Multimedia...
Bose Companion II Computer Speaker: The AC power adapter burnt
My puppy chewed through the cord for my a/c adapter, I just took the speakers into Circuit City, and they found me a workable replacement (the replacement isn't BOSE, but it works just fine).  Hope that helps!
Feb 11, 2009 | Bose Companion 2 Computer Speakers
Bose Companion 2 Series II Multimedia Speaker System (2-Piece) Logo
49 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
