Question about AZEND GROUP CORP Envizen Digital V7011 4 GB Tablet - 7 - 1 GHz - 512 MB RAM - Android 4.1 Jelly Bean - Slate - 800 x 480 Multi-touch Screen Display
Tablet battery Envizen V7011
Battery goes dead after 30 minutes
ENVIZEN EVT10Q TABLET CHARGING CORD. WHERE CAN I GET A REPLACEMENT??
Fixya neither sells replacement cords nor advises sources.
Aug 19, 2017 | Tablets & eReaders
Why my tablet envizen maxmade model#V7011
You may need to download Adobe Flash Player. Im not sure how to check on a Tablet but if its anything like a aptop go to the control panel and list all programs and see if your running Adobe. Thats the 1st place to start.
Aug 14, 2014 | Tablets & eReaders
Reset pc
www.envizendigital.com/index.php/support
Jul 02, 2014 | Tablets & eReaders
Ipad only charging to 30% overnight
Might be a faulty charging cable I'd suggest buying a new one , also never let the battery run completely dead plug it in before it goes off .
Dec 29, 2013 | Apple iPad 32 GB WiFi Tablet PC
Tablet won't charge
With your tablet unplugged, press and hold the Power button for around 30 seconds. Then place your tablet on the charger (preferably the home charger) and wait a couple minutes. Then press and hold the power button for around 30 seconds again. If this does not help, then the battery may be bad. Storing a lithium-ion battery should done with no less than 40% battery life left, otherwise the battery voltage or power can go below the safety net (li-ion batteries are not fully dead when your device tells you they are. Once the battery reaches below the safe level, the battery is no longer good or safe to use anymore).
Aug 10, 2013 | Samsung Galaxy Tab Tablet PC
When I try to charge my samsung galaxy tablet a yellow triangle pops up on the battery sign
I had this same thing. The Batter image had a red line on the right side and the yellow triangle had an explanation point in the middle.
I searched the net and found a few solutions.
1. Hold the power button down for 30 seconds.
2. Hold the power button down and the volume down button at the same time for 30 seconds.
3. Just let it charge and over night and it should go back to normal.
I did all 3, in the order I wrote them. While in step 3, after about 5 minutes I pressed the power button and it showed that it was charging normal.
Hope this helps.
Dec 04, 2012 | Samsung Galaxy Tab Tablet PC
AZEND GROUP CORP Envizen Digital V7011 4 GB Tablet - 7 - 1 GHz - 512 MB RAM - Android 4.1 Jelly Bean - Slate - 800 x 480 Multi-touch Screen Display Logo
Top AZEND GROUP CORP Tablets & eReaders Experts
Are you an AZEND GROUP CORP Tablet and eReader Expert? Answer questions, earn points and help others
