Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
My fisher & paykel dd603 top drawer is sticking and won't close without force. After taking it all the way out, we saw the the top piece (inside the dishwasher) is loose and is obstructing and pr
We did not see any missing screws, etc. How do we repair this and get it tightened? The sides are loose as well. We checked the same piece on the bottom drawer (by taking the bottom drawer out) and the top unit is tight and secure, as well as the side pieces. Not sure how to fix this?
  • Fisher and P... Master
  • 3,247 Answers
The drawer lid seal is the problem. It is likely the actuator motors controlling the lid position are either faulty or need rebalancing. Happens if the dishwasher lost power in the middle of the cycle or the drawer got pulled out when running. It is a big job to fix as the lid seal and actuator yoke and arms will need to be taken out and refitted. ALos it is likely the gaskets on the lid seal could be damaged and need replacement.
Posted on Jan 19, 2014
4 Suggested Answers
SOURCE: Fisher and Paykel DD603 top drawer jammed and will
Hey, I had this problem before!!!! Just unplug the unit off and wait about 10sec and plug it back on.....that usually does the trick.
Posted on Nov 26, 2009
  • 3247 Answers
SOURCE: fisher paykel dishwasher DD603 drawer is open but locked
i think you have to press the key/ lock button until the symbol disappears. You will find the exact button for your model in your owners manual.
Posted on Dec 13, 2009
Daniel S
  • 4323 Answers
SOURCE: Fisher Paykel DD603 SS - After
Hi
Plesae check the below procedure to remove the drawer----
Slide open drawer.
Locate draw pin on either side of the tub.
Using a sharp pair of long nose pliers or slip jaw pliers grasp the center dividing web of the pin and pull away from the tub to remove the pin. Support the drawer front with your hand while doing this.
Note: The pin web is vertical.
With both pins removed the bottom of the drawer front can now be eased out slightly.
Now carefully pull the drawer front down to allow it to come free from the handle and top locating slots.
Carefully remove the earth wire from the tab on the drawer front. (if it is an integrated model you will also need to unplug the integrated badge from the isolating module)
Refit in reverse manner ensuring the drawer slides are right forward and the pin secures through the hook on the front end of the slide.
Note: When reinserting the pins make sure the dividing web is vertical.
Hope this helps... Please post back if you need more information.
Daniel
Posted on Dec 27, 2010
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
Top drawer won't close
After completing a cycle the top drawer feels like it will not open or the top of the drawer has fallen down. I've since forced it open but, now it feels like it will not close. I did not force it to close. How do I remedy this problem?
Mar 02, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Why won't my top drawer start
I am assuming you have a double drawer unit DD603. A drawer will not respond when you press Start button for several reasons. Assuming the panel lights are on, there could be a problem with the lid seal motor or the sensor that detects drawer is closed or blocked outlet hose or dirty panel. Take a damp clean cloth and wipe the inside of the drawer door panel. The dishwasher is very smart and checks for the condition of the dishwasher before starting. If turning off the mains power and turning it back on does not change the situation you will need a technician to attend to it.
Feb 07, 2013 | Fisher and Paykel Dishwashers
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel dd603 stops while in cycle and beeps but no error codes show
Does it open the lid?... and does the display flash, as if paused?... if so, just clean the closed sensor lenses, top right hand corner of the drawer, and the little piece of plastic they shine into on the housing.
Nov 29, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher paykel dishwasher DD603 drawer is open but locked
Nov 25, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel DD603 top drawer jammed and will not opem/close properly without brute force!! Please help!
Oct 25, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher Paykel DD603
The top drawer on our DD603 top lid doesn't seal allowing water to spray out and down the sides.
Aug 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
117 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
