Question about Home
Sioscan atomic clock
Correct time but pm is wrong
5 Suggested Answers
  • 37 Answers
SOURCE: S10Scan atomic clock model 87310 time is 4;pm should be 10:am
Hi
Time zone setting
Language Setting
The weekdays can be displayed in LCD1 with the pre-set languages: US English, French and Spanish.
1. Set the desired language for the weekday display in LCD 2 by use of the + key.
2. Press the SET key to enter the mode “Manual Time Setting”.
Manual Time Setting
In case the Skyscan Atomic Clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
Note:
In 12 hours mode the time will be displayed with an additional “PM” for the time from 12:00 noon until 11:59.
1. The hour digits will start flashing on LCD1. Set the desired hours by pressing the +key followed by pressing the SET key.
2. Now the minute digits will start flashing. Set the desired minutes by pressing the +key . If the + key is held, the units will increase by 5.
3. Press the SET key to move to the “Year Setting”.
Note:
The unit will still try and receive the signal every day despite it being manually set. When it does receive the signal, it will change the manually set time into the received time. During reception attempts the WWVB tower icon will flash. If reception has been unsuccessful, then the WWVB tower icon will not appear but reception will still be attempted the following hour.
WWVB time reception takes place from 12:00 am through 6:00 am each day (attempts WWVB reception every full hour within this time frame). When the time signal is received for example at 1:00 am, the Skyscan Atomic Clock will not attempt to receive the WWVB signal for the remaining hours until 6:00 am. Therefore, the next signal attempt will take place between 12:00 am and 6:00 am the next day. The other times WWVB reception takes place, are upon setup and after manual time set exiting mode. Reception is generally not possible during daylight hours due to the interference of the sun.
for more details see user manual...
Thank you
Posted on Dec 12, 2008
BillB-SA
  • 2761 Answers
SOURCE: have a sky scan atomic clock model 86715. it does
If this model has a DST switch on the back, make sure that it's turned ON. If there's no DST switch you can force a manual change by changing the time zone setting, but you'll need to do that twice a year. Also note that if the clock is more than two years old, turning the DST switch ON will make the clock conform to the old DST changeover dates.
Bill B
Posted on Apr 04, 2010
gopakumarg43
  • 74211 Answers
SOURCE: I have an atomic wall clock which sets itself to
Hello
This is a typical fault that I haven't faced so far. Just replace the batteries with now ones and check. This is the only thing we can do with it. If it doesn't help you, the time synchronising section in the clocks' circuit is fauty. This section is integrated with the IC, and nothing can be done; the IC is a non-replacable one too. If so, you just determine what to do. OK.
Posted on Oct 14, 2011
jrh8879
SOURCE: set correct time for sky scan atomic clock model 87310
How do I reset the time on my atomic clock 8700?
Posted on Feb 08, 2013
How to reset time on SioScan travel alarm clock model 31420E
Google (SioScan)(31420E)(manual) without parens to get instructions.
Nov 06, 2016 | Home
How do I reset time and date on SioScan Atomic Clock? I need Arizona time zone - i.e. no daylight savings time
Put it into settings and then adjust time/date. It's not related in any way to temperature.
Apr 24, 2015 | Home
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Apr 30, 2014 | Timex T065s Solar Powered- Radio...
I just found a sio/scan temp transmitter in my flower bed, what is this and do i need it?
You only need it if you have a SioScan atomic clock to read the temperature it transmits.
Jun 28, 2010 | SkyScan 86709 Atomic Wall Clock
My SioScan clock is two hours behind the actual time. Instructions lost. Can I reset it? How?
I searched on "sioscan" and all I could find was "skyscan".Is this your clock?
If it is, you can copy "skyscan.info/content/quick-ref.html" into your search engine, you will arrive at the skyscan web site instructions.
Mar 11, 2010 | Watches
Savings time
This is more of a Clarification than a solution.
I've determined that the SS-5000 is not recognizing the changes to DST that happened in 2007.
From 1986 to 2006 this was the first Sunday in April to the last Sunday in October, but starting in 2007, it is observed from the second Sunday in March to the first Sunday in November, adding about a month to daylight saving time.
So in March the clock is still trying to keep the "earler" time and in November it's trying to keep the 'later' time.
I'm contacting HomeMedics Support to see if there's a resolution.
Mar 17, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Temperature Transmitter
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers
Oct 16, 2007 | SkyScan 86709 Atomic Wall Clock
Home Logo
123 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
