Question about Samsung Ezon Digital Door Lock
Alarm from the digital door lock
The alarm came on and off every few minutes, even after the battery had been changed, pls advise
How to resed the alarm on my 2004 mazda 6?
Try closeing all the doors lock it with the key on the driver door if that doesn't work try changing bat on your remote also try disconting battery for few minutes
Aug 24, 2014 | Cars & Trucks
After changing the battery on my VW Sharan 2005, my central locking is no longer working. The passenger door, rear doors and boot are locked by the central locking. The drivers door only works with the...
when you disconnect the battery you corrupt the cpu program in the ECM
mostly the fix is to use a fault scanner tool to reset the program
Mar 28, 2017 | Cars & Trucks
How to disactivate the alarm on a avenger 2008 dodge
pull the fuse out for it or disconnect the battery on it for a few minutes and this will reset it
Sep 27, 2011 | 2008 Dodge Avenger
I had my battery change and now when I turn off the vehicle and lock it a few minutes latter the horn and the light start going off. WhaT can I do I have a 2004 ford f150 extended cab
It sounds like you have a factory security system. Even if it is aftermarket they sometime t need to be reset. First find out if the security system has a balance system. This will set off a horn or alarm if the vehicle is rocked or moved. If not, try resetting by unlocking all the doors with remote. Disconnect the negative cable and leave it off for a few minutes. Then reconnect it and start the engine, turn it off and lock the doors and wait. Beyond this I have nothing further
Aug 22, 2011 | Ford F-150 Cars & Trucks
My system is on a silent mode or something, it still engages and dis-engages, and locks and unlocks, just that when I press the transmitter, it doesn't beep and horn doens't beep.
take the battery out for a few minutes then replace it, or if you have many custom settings, you have to press and hold the side button until options pop up.
IM GONNA BE HONEST, I HAVE NOT USED THIS DEVICE, BUT I HAVE A PRESTIGE ALARM WHICH IS MUCH THE SAME.
Hold the buttons in combinations. by themselves and so on until you get a menu, then press a button to change the value or the option, this is the best way to get to know your 2way responder....
GOOD LUCK AND PLS RATE THIS POST FIXYA!!!!!
Jun 03, 2010 | Install Essentials 489P Responder 2-way...
General Power failure
try locking and unlocking the driver's door with the key, this should disarm the system
Sep 26, 2008 | 1997 Jeep Grand Cherokee
Samsung Ezon Digital Door Lock Logo
20 people viewed this question
Top Samsung Home Security Experts
Bill
Level 1 Expert
bobby little
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
