Question about EnGenius ENS202 Long-Range 2.4GHz Outdoor Wireless N300 Bridge/AP
My engenius ens202 will not let me access the start up page
I cannot access the start up page when I type in the ip address into my browser
remt23c
  • 78 Answers
SOURCE: EOC-3220 connects but no internet access
What are you using for Internet connects? do you have the Access point connected to a Router. or is it connected to the Cable or DSL modem. I will need more information to complete this. If you have a router is is set to give an IP address or do you have a static IP? If it is set to give a Dynamic ip change the access point to recieve ip address from router and same with computer. If your connected directly to the Modem with the access point and you only have one IP address it will be used by the access point and not allow the computer to connect.
for more help please provide your internet (DSL, T1, CABLE) if you have router,  how it provides IP, and how access point is connected to it.
Posted on Oct 31, 2007
davecon
  • 85 Answers
SOURCE: Engenius EOC-3220+
if you have a the router's manual,there is a guide on how to do that.
but in case you dont have the manual go to the device website and get some guide.default ip varied from different manufacturer
Posted on Apr 23, 2008
  • 351 Answers
SOURCE: resetting EnGenius EOC 3610
Dear Venmattey,
please follow these steps, it works:
1. Connect the EOC-3610 to your computer with a null modem serial cable.
2.Start a HyperTerminal session: Click Start and then select Programs-> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3610.
b. Select correct COM port. Ex:COM1.
c.Set baud rate as "38400", data bits "8", parity "none", stop bits "1",and flow control as "None". Then press “OK” to bring up theHyperTerminal window.
d. Unplug the power on the POE injector and wait 5 seconds then plug the power back in.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
NEW: Keenan Systems has written a software that will soft reset the 3610 series back to factory reset. Thisfree software is provided "AS IS" by Keenan Systems and is notsupported or guaranteed by EnGenius Technologies. Use at your own risk.
Be Happy Always
Regards
Posted on Dec 03, 2008
Macs R We
  • 481 Answers
SOURCE: I configured my EnGenius outdoor radio to AP and after rebooting
That's because the default address in AP mode is 192.168.1.2.
Posted on Oct 28, 2009
Macs R We
  • 481 Answers
SOURCE: Hi, I cannot setup my
You need to enable the DHCP server on the EOC-2611P. Then it will negotiate an IP address with your PC without you having to set one by hand.
Posted on Oct 27, 2010
ENS202 installation and setup
It's a bridge. Are you sure it's not being found? Or is it simply extending your wireless network correctly and you only see one network? Bridges and APs usually have separate IPs, but the same network SSID is broadcast from them.
Mar 23, 2014 | EnGenius Outdoor 2.4ghz Wireless N300...
Tip
Having trouble accessing router's setup page?
Note: If you cannot access the router's page, check the computer if it's getting a valid IP address from the router. Click Start then type CMD on the Search box then press Enter. A black window called Command Prompt will appear, just type IPCONFIG then press Enter. It will display the IP address.
- Scenario 1. If the IP address starts with 169.x.x.x --- not getting IP from router
  • Scenario 2. If the IP address starts with 192.168.1.x --- getting IP from router
  • For scenario 2, since the computer is getting IP from the router, try to PING the router to test connectivity. Open the Command Prompt again, type PING 192.168.1.1 then press Enter. If you see the word reply 4 times then it means the computer is communicating with the router.
  • Clear the cache, cookies and history of your Internet Browser then try to access the router page again.
on Dec 11, 2011 | NetGear Computers & Internet
I can't enter the web from 192.168.1.1 or 192.168.1.2 how i can enter web setting AP senao 8610S? what sould i do?
Start>Run>Type in CMD
Press enter
Type ipconfig
Note your gateway
Go to internet explorer and type your gateway in by itself. i.e. 192.168.1.254
Press enter
If this does not work attempt reattempt the gateway address but replace the last number with 254.
i.e. gateway=192.168.2.1 instead type in 192.168.2.254.
Mar 03, 2011 | EnGenius ECB-8610S 802.11a/b/g Wireless...
I need the ip address
Welcome to Fixya. If you need the Ip Address of the router to access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.0.1, the Default username is admin and the password is blank.
Thanks for using Fixya.
Feb 05, 2011 | D-Link AirPlus DI-524 Wireless Router
My EnGenius ESR9850 router is not broadcasting the wireless connection how can i fix it
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless settings Then turn the wirreless in also enable broadcast.Then save settings and restart router. If you are not able to access it with above ip then RESET it for that press RESET button for 10 seconds it is in back side of router then access it with above ip and set WAN settings of router as your internet service provider settings. Turn on wireless and enable DHCP if you want ip from router. Let me know if you need further assistance. Thanks for using FixYa.
Aug 13, 2010 | EnGenius (ESR9850) Router
I set up the Engenius EAP as a repeater and can connect to it with my lpatop and Iphone. When I try to connect another laptop I have excelletnt connectivity reception, but Internet Explorer cannot display...
Signal is only one part of the complete connectivity problem. Your lack of connectivity is almost certainly due to some other component, such as your second laptop having an incompatible static IP address specified, or no DNS servers specified.
First, ensure your PC is configured for a dynamic IP address. Once you have acquired good signal and connected, check to see that you have received a dynamic IP address. If that works, open IE and type in the numeric IP address if your EPA repeater. If you get a response, the problem is not your wireless connection or local IP address. Now type in the IP address 74.125.19.103 . If you get a response, your problem is that you have no DNS servers specified.
Feb 28, 2010 | EnGenius EAP-3660 802.11b/g Wireless...
I cant reset my senao eoc3610
1 ) Check if IP address is the correct address of your Gateway.
Check if you can ping.
Be sure you have your Java enabled
Some router requires a specific Browser (IE6 or IE7) and cannot respond to different browser.
Be sure to remove any Java protection from your Browser.
Check with user manual if IP address requires also a specific port number ( 8080 or other).
Be sure to Connect Router using Lan cable
2) Change your PC IP setting to same subnet as your router
Control Panel / Network settings / properties of TCP/IP define an IP address and a subnet mask compatible with Router as gateway.
3) If you are not sure of Router IP address use reset button on router back to factory default; use this to configure router.
Dec 27, 2008 | EnGenius EOC-3220 (EOC3220)
Getting to setup pages
look at your DHCP client table on your router to find the IP address of the device.  You can identify if via the MAC address on the table (and sticker the 3220)
May 28, 2008 | EnGenius EOC-3220 (EOC3220)
After a windy day lost wireless connection
For a new unit disconnect the eoc from the network and connect directly (through POE injector of course) to your laptop/pc.  then in network connections setup your lan port TCP/IP settings as follows.  ip 192.168.1.10 subnet mask 255.255.255.0 then gateway 192.168.1.1
point your browser to 192.168.1.1 or 192.168.1.2 (one if it is in AP mode and the other address works if it is in bridge mode).
When configuring, I assign it an new static IP outside of the DHCP assignment range.
To see how it is setup afterwords you can use hyperterminal with a null modem cable to view the current config.  instructions on the engeniustech.com support page.
Confirguration
After installing the hardware and physical mounting, basic configuration is something like below:
1. Set your computers TCP/IP address temporarily to be a static IP address such as 192.168.1.5;
2. Open your browser and type in 192.168.1.1 in the address bar. The EnGenius password prompt should appear. The default user is admin and the password is also admin. The control interface should now be accessible;
3. Under the Wireless heading click on Site Survey. This will display all the access points in your area. Your ISP or to whatever WiFi network you would want to connect should be listed in the ‘Wireless Site Survey’. Select the access point with the highest signal level or your choice. Click ‘Connect’;
4. After clicking ‘connect’, it should confirm that the EnGenius has connected successfully;
5. Click Ok and it will take you back to the list of wireless site surveys;
6. To confirm that the SSID has been changed go to the ‘Wireless Basic Settings’ page which is in the Wireless submenu in the left side bar. Once on the wireless page go to the box with SSID. The value should read "Your ISP or the WiFi network you would want to connect"; this has to be exact and case-sensitive to connect successfully.
This is just the start, all settings are configurable and actually depends as to how you would want to use the device; as a WiFi Access Point, as a client router mode or Wireless outdoor bridges in WDS mode.
After all settings have been changed to your requirement(s), go back to the PC's control panel and your network connections, and change your TCP/IP address back to DHCP settings (obtaining an IP address automatically). panel window.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 15, 2008 | EnGenius EOC-3220 (EOC3220)
EnGenius ENS202 Long-Range 2.4GHz Outdoor Wireless N300 Bridge/AP Logo
83 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
