Question about Tablets & eReaders
How to unlock a locked ipad - Tablets & eReaders
I just bought a iPad off gum tree and my ipad locked and the sellers numbers off
There are two scenarios here
1. It is stolen and is PUK Locked. This can only be unlocked by the cellular network holder who owns this iPad, irrespective of whether it takes calls or not. Cellular providers have iPad plans. If so it is locked with a 128 bit encryption key at firmware level. The key is 6 numbers.
2. It is a consumer set passcode and you don't know what it is. It sounds like you saw it working? Anyway, the only way past this is by doing a Factory Reset. To do this you need a computer. Download iTunes. Set up an Apple Account, or use the one you have. Connect the iPad and go to Properties for it and do Factory Reset. Once finishes, set it up for you, with your Apple ID and your own lock code.
Aug 30, 2017 | Tablets & eReaders
I need help with the passcode for my ipad
Is there anything wrong with the passcode? If your iPad is locked and you forget the passcode, please follow the steps below to unlock it.
1.Connect your iPad to your PC or Mac.
2.Select your device in the iTunes sidebar, and click the"Summary" tab.
3.Click "Check for Update". iTunes will show you if there any new version of iPad software is available.
4.Click "Restore iPad". You can finish the restore process by following the instructions given. During the process, a recommend that tells you to back up your files will be given. You can restore your data after the process is complete.
Now, you must have restored your iPad.
Note: Even you bring your iPad to the Apple service center, Apple staff also need to restore your iPad to unlock it. That's to say, you need to erase everything on it.
http://www.leawo.org/tutorial/forgot-ipad-screen-lock-password-how-to-recover-data-from-locked-ipad.html
Nov 08, 2016 | Apple iPad Tablets & eReaders
If i bought a iPad but its iCloud locked and erased how can I unlock it or do I just have to go to the apple store.
icloud locked is a personal security code not apples and apple will not be able to help you what you bought is a parts ipad
Sep 09, 2016 | Apple iPad Mini
I have a iPad mini that says activation lock. I bought from someone. How do I unlock it?
This means the ipad is reported stolen by the owner and is being tracked.......the owner is the only person who can unlock it!
it is a security app, 'find my ipad' and cannot be unlocked without the apple id!
Sep 07, 2016 | Apple iPad Mini
How to unlock an activation locked Ipad Mini
In order to unlock an activation locked iPad, you need to get the activation lock turned off. If you have iOS 8 or above, watch this video on how to do it.
Aug 23, 2015 | Apple iPad Mini
How to unlock an icloud locked ipad 2
The answer was already here:
Unlock iCloud iPhone 6S, iPhone 5S, iPhone 7, iPhone 6S+, iPhone plus
Download from:
http://unlock-icloud.com
Unlock and remove iCloud for:
All iOS
iPhone 7
iPhone 5S
iPhone 6
iPhone 6 plus
iPhone 6S
iPhone 6S plus
All iPad's and new models
Remove iCloud activation lock, bypass iCloud lock
Real and working by software, work on all Apple iPhones
Trusted solution work 100% i recommand it's verified!
The software is easy to use and the support team from unlock-icloud.com offer good technical support with team viewer and video for unlock icloud and iphone repair solutions. The signal work excelent after i have used this software. The software is clean no viruses or other bad things like other software from internet.
With this software i managed to repair my iPhone 6 iCloud errors and bypass activation lock. It's a realy gsm repair tool.
Feb 21, 2015 | Apple iPad 2
I appear to have locked my ipad how do i unlock it lock off my ipad
if you remember the password then slide to unlock or else if u dont remember it you have to put it in to dfu mode and then restore it with itunes. make sure you have backed up your ipad.
Feb 15, 2015 | Apple iPad Tablets & eReaders
My iPad has froze up and I can't get it off and lock
Try pressing the home and lock/unlock buttons on your iPad for about 10 seconds. The iPad should restart and soft reset. This won't delete anything. It will just force it to restart.
Mar 13, 2014 | Apple MD065LL AT&T 3G 16GB iPad 2 Tablet
Screen wont rotate ... How do I unlock
Double click home button
then scroll with your finger to the right look for first icon with a 3/4 circle with arrow tip that icon allows you to lock/unlock portrait mode
Mar 29, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
325 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
