Question about Woodcraft Toys
I have a p301 spitfire and have no idea on how to build
What is the correct plug for the pope spitfire 40 lawnmower
luckily spitfire 40 use a briggs and stratton 4 stroke
so not too many variables
take the one fitted in it with you
could be any equivalent to a cj8 to J19 with a short thread
Sep 06, 2016 | Garden
1974 truimph spitfire mk4 firing order
Edward, Firing order 1-3-4-2 for spitfire. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Engine Tuning Data for the Triumph Spitfire and GT6
Distributor drive gear and firing order question Spitfire GT6 Forum...
getting spark plug wires back in the right order MGB GT Forum MG...
http://www.repairservicemanuals.com/Triumph
Jun 14, 2016 | Triumph Cars & Trucks
I have a technical question about the SU carbs of my 1966 Triumph Spitfire MK 2.
the little plastic /rubber bit has come off the shut off valve ,although you have no doubt found this out by now .
Aug 20, 2015 | 1966 Triumph Spitfire
Considerable oil consumption with no visible leaks and a p301 code on my '01 e-250
p301 indicates number 1 cylinder is misfiring,that with the oil consumption, would indicate either worn valve stem guide,or worn piston rings to check you need to carry out a compression test,if compression is low the head would have to be removed to see which of the above is the culprit
Apr 04, 2014 | 2002 Mercury Sable
2003 blazer p301 code ive changed coil plugs check engen still flashing when accelerating
The flashing light means the problem is serious enough to damage the catalytic converter.
The code means cylinder 1 is not producing power. So it could be fuel, compression, or ignition related.
Feb 05, 2014 | Chevrolet Blazer Cars & Trucks
Check 3 codes at once P301, P302, P303 On ford 3.0 V
Those P300 codes are cylinder misfires
from bad COP Ignition Coils
Feb 25, 2013 | 2001 Ford Escape
I need a transaxle for a 1410 spitfire scooter
TRANSAXLE FOR SPITFIRE 1410 SCOOTER POWER CART.
CALL 803 - 749 - 4449 = ACTIVE CARE MEDICAL INC.
TELL THE SECRETARY YOU WANT TO SPEAK TO THE TECH-MECHANIC " JEREMY ".
HE WILL QUOTE YOU A PRICE OF $266.40 + $12.00 SH = $278.40.
DELIVERY TIME ABOUT 5 - 7 DAYS.
Sep 22, 2010 | Electric Mobility Blue Spitfire 1410 ...
Oil type
I don't know what a pope spitfire is, but the post indicates it's a pushmower -- in that case, I would use 30 W non-detergent.
Charlie
Aug 29, 2009 | Garden
1972 Triumph Spitfire, 3rd gear grinding
Jumping out of third was a common problem with the Spitfire quick changing up from forth gear would beat the syncro and chip the teeth on the drive dog then the bits would stop the syncro from engaging fully and it would jump out. If you replaced the syncro and the drive hub it may just be a bit stiff, the selector also wore quite quickly and misaligned the drive hub causing it to be hard to select.
I will scratch about in my very old manuals and see if I can find the spitfire gearbox manual, If I can I will post it.
Jul 30, 2009 | 2006 Triumph Tr 7
Toys Logo
Top Woodcraft Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Woodcraft Toy Expert? Answer questions, earn points and help others
