Question about Black Box Frame-Relay Access Switch Multiplexer
Electric windows at drivers and passengers side not working
Window on drivers side was not working and now the passenger side does not work would like to find out were the relay switches are
  • Robert Kitaji May 11, 2010
    You need to resubmit this problem with the auto maker, model, and year specified. This problem shows up under the PC computer section.
    Brigadier General:
  • 10,406 Answers
Try posting your question to the "automotive" category, not the "computer network hardware" category:
All Products > Black Box > Frame-Relay Access Switch Multiplexer > Troubleshooting
Posted on May 21, 2009
My passenger side electric window stopped working on my 1991gmc sierra 1500. The passenger side switch panel don't work for the window but works for the lock. Driver side master switch doesn't work for the...
The odds of both switches going bad at the same time is high, remove the door panel and tap on the window motor with a hammer, while trying the switches. I may have jammed up. Ground a test light and check the motor connection, while trying the switch, power will show on either side depending on if it turning up or down
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_4c166ba81493f541
Mar 19, 2015 | Cars & Trucks
2005 Dodge Durango passenger window wont go down from drivers side switch
It sounds like everything else and the wiring is okay, only that button on the driver's switch is not working. I would try a new switch, if you see nothing wrong with the electrical plug for it when you take it off.
If that down wire was broken somewhere from the driver switch to the passenger door, I don't think the driver's switch would work for it either way, up or down. And same, neither would the passenger switch work. I think the button for down is not making contact somehow, and right in the switch.
Jan 10, 2013 | 2005 Dodge Durango
Ford Ka electric windows passenger works drivers doesn't. I replaced the switch and still nothing. If I diconnect the drivers switch the passenger window stop s working so there's some connect
The relay operates all the windows. The drivers door switch is the master and has to be connected for the rest to work. It sounds like you have a bad motor or a bad connection on the motor in the drivers door.
Feb 04, 2018 | Cars & Trucks
Passengers side electric window doesn't raise when toggle is pressed on main panel
if passenger window switch work passenger side window and driver side master switch dont. master switch either locked out or master driver window switch is bad.
Oct 25, 2012 | 2002 Jeep Liberty
Drivers side electric window will not work even though passenger side window still works from the same switch.
sounds like the driver`s window switch is the problem as the passenger driver`s door switch supplies power to the passenger window motor through the passenger switch,even when controlled by the driver`s door switch
Mar 11, 2011 | Ford Focus Cars & Trucks
Passenger side electric window doesn't work from passenger side. workes from driver sid like to see electrical print
If works from driver's side ok then you have a bad switch on passengers side cause the power comes from driver's side switch
Feb 07, 2010 | 2004 Dodge Ram 2500
Electric window drivers side not working
If the switch on the passenger side works, it should not be the relay. These switches are usually the fault, and can be dissasembled carefully and contacts cleaned. Theyre not that expensive anyway if I remember last time.
Other things to consider are the wires coming into the drivers door. make sure that one of them is live, and if you ascertain which on is the live, which the ground/earth, and what is the window motor one, you should be able to test the wiring.
Jun 01, 2009 | 2006 Peugeot 505
ELECTRIC SEATS &PASSENGER SIDE WINDOWS DONT WORK
2003 surbarban driver seat and passenger windows have common fuse/breaker under hood in fuse panel. 50 Amp fuse upper left of box, marked mped this is a big fuse not the little ones.
May 20, 2009 | 2003 Chevrolet Suburban 1500
Passinger electric window not working
Hello, from the sounds of it your problem is the switch for the window. The passenger side window can be either the drivers side or passenger side switch. You will need to check to see which switch isn't letting the voltage thru.
Mar 31, 2009 | 2002 Ford Escort
All of a sudden the driver side window will not roll up.
is it electric windows? if it has electric windows does the passenger window roll up using the switch for it on the passenger door panel? if it works on the passenger door panel and not on the driver's door panel , then your switch on the drivers door panel is bad... replace it.
Oct 13, 2008 | 1999 Oldsmobile Cutlass
Black Box Frame-Relay Access Switch Multiplexer Logo
85 people viewed this question
Top Black Box Computers & Internet Experts
Glyn
Are you a Black Box Computer and Internet Expert? Answer questions, earn points and help others
