Question about Samsung SCX Office Equipment & Supplies
Firmware downloads scx4300.exe 1.13 firmware
Samsung scx4300 firmware 1.23 fix
Flashing firmware may lead you formater damage after a period of time. Better way is put a replacement chip on your cartridge.
Dec 19, 2013 | Office Equipment & Supplies
Tip
Firmware SCX4623 Reset Counter
Easy to Reset via firmware your pritner n work life time
SCX4623
SCX4600
SCX4601
ML1915
ML2855
Ml2520
ML1911
SCX4300
ML1640
Ml2240/2245
all new update.
after work life time. no need chip
Contact:
Skype: Indianrefiller
email: pateltraders@gmail.com
mobile: +91 9825523201
www.chipresetters.com
on Sep 07, 2010 | Office Equipment & Supplies
Toner exsusted replace toner
To solve problem you need to download PATCHED by scx4300.exe 1.13 firmware (which you can Google and download it online)where additional reset procedure was implemented in.
To patch firmware you need to unpack archive in any folder then open commad line interface go to this folder then type "fix4300.exe SCX4300_V1.13_Fact_romdl.hd". If no error occurs you will find file "FIX_SCX4300_V1.13_Fact_romdl.hd". It's a patched firmware. The next step is to download this file to printer. Enter TECH mode, activate download by "Menu > Data Setup > Flash Upgrade > Local [OK]" then type in command line "usbprns2.exe FIX_SCX4300_V1.13_Fact_romdl.hd" to start download. During download printer displays: Data receiving > Flash erasing > Flash Programming > Checksumming > Download Ok then printer will restart. It's all.
To reset all counters and unblock printer enter Tech mode go Data Setup > Clear counters. In this menu you will find "Clear All CNT" instead of "Total Page CNT". Choose "Clear All CNT" then press [OK]. Printer will display "warming up" and LED will yellow for seconds then change to green. After reset all counters in report will be zero and toner 100%. You may repeat this procedure as soon as you need.
Feb 01, 2011 | Samsung SCX-4300 Monochrome Laser...
My samsung printer model is scx4300 and it shows tonner exhust and how i reset the chip of tonner please help
This is a link to view how to reset: http://www.youtube.com/watch?v=Qzc9JImUcak
This is a link to download firmwares (version 1.13, 1.16, and 1.18_fix) and download software to update firmware files to printer: http://dox.abv.bg/files/listtree
MOST IMPORTANT:
1. Push 8 times button MENU then OK to print a report and view your version of firmware
2. REPLACE FIRMWARE VERSION 1.13 ONLY WITH 1.13_fix
3. REPLACE FIRMWARE VERSION 1.16 ONLY WITH 1.16_fix
4. REPLACE FIRMWARE VERSION 1.18 ONLY WITH 1.18_fix
5. REPLACE FIRMWARE VERSION 1.21 ONLY WITH 1.18_fix
6. DO NOT REPLACE FIRMWARE VERSION 1.23, I DON'T HAVE FIRMWARE VERSION 1.23
IF YOU REPLACE FIRMWARE VERSION WITH WRONG VERSION A "SCANNER ERROR" OCCURS AFTER SEVERAL MONTHS WHICH MEANS YOUR SCANNER MATRIX IS BURNED OUT AND MUST BE REPLACED
GOOD LUCK!
Jan 18, 2011 | Samsung SCX-4300 Monochrome Laser...
Samsung scx 4300 toner reset software download
my printer scx4300- problem for toner empty or replacement toner, but toner is refiled. this download software
Jan 11, 2011 | Samsung SCX-4300 Monochrome Laser...
My scx4300 mfp is giving scanner error and scanner is hitting left side wall
Are you uograde firmware , if yes then wrong firmware , please upload write firmware to reset printer. www.nakshatraworld.com
Oct 21, 2010 | Samsung SCX-4300 Monochrome Laser...
Printer sowing message download from pc
hello you have to reset your current firmware check this video
www.youtube.com samsung scx4300 reset
this is the way reset your machine
Aug 19, 2010 | Samsung SCX-4300 Monochrome Laser...
Toner low problem after refilling
hello toner refill is not good for this model .i think u have to reset toner cartridge .first download firmware. see www.youtube.com 'samsung scx4300 chipreset' thank you
Aug 12, 2010 | Samsung SCX-4300 Monochrome Laser...
Dear sir afwan scx4300 scanner error what to ...
Scanner is damaged or You had run wrong reset software (firmware)
Reset scx 4300 through firmware upgrade. It is permanent solution
info@nakshatraworld.com
May 20, 2010 | Samsung SCX-4300 Monochrome Laser...
81 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
