Question about Staples 2x1 USB Peripheral Switch
BOTH PORTS NOT WORKING - Staples 2x1 USB Peripheral Switch
My Audio Isn't Working
Try another device in that port just to make sure the device is working correctly. Try the headsets in another port just to make sure it isnt a bad port.
If the device works in another port then you have a bad port even though the computer sees it.
If the device does not work in another port and a different device works in the same port then you headphones are bad.
Jul 15, 2016 | Imicro IM320 USB Headset
How do you open a port
  1. USB ports stopped working Acer Aspire 5750 - Tom's Guide
    www.tomsguide.com/.../usb-ports-stopped-working-acer-aspire-5750.ht... Apr 23, 2014 - USB ports stopped working Acer Aspire 5750. Tags: Aspire. Laptops... I have an Acer 5750 none of the USB ports work I tried disabling them all ... on Acer Aspire 4935 laptop Forum; Acer Aspire Computer - USB not working ...
Jul 11, 2015 | Acer Aspire Computers & Internet
USB ports not working ... front ports are working while back ports not... what may be problem.. as drivers are installed !!
There is a cable between the motherboard and the USB ports which is missing or pulled out.
Oct 10, 2014 | Computers & Internet
ONA11H0089
Did it ever work? Is the port it is connected to the correct port? Is the port active? Try a different port? If yes, try a different keyboard in the port. Does it work? If not, you may have a blown port.
Apr 02, 2014 | Computers & Internet
USB PORTS NOT WORKING
try to update or download the usb cord of your laptop
Nov 27, 2013 | Toshiba Satellite C655-s5090
Usb port not working
Printers are particular about which usb port they are plugged into, a virtual printer port is assigned to USB1 in the computer, when you select the printer port for it to use. You may need to plug the printer into each USB port, until you fine the USB port 1 which it works in, remember to always connect it to this same usb port, otherwise it will not work. There is only one USB port number 1.
Apr 10, 2013 | Brother MFC-7340 All-In-One Laser Printer
PS/2 mouse port not working?
Hello fredbeer,
Besides the obvious checking with your device manager, you can download a port test kit HERE. That will be able to test if it's working. The other thing you can do is switch the keyboard into the mouse port and the mouse into the keyboard port. You should get some errors, if not, one of them will work and the other won't. Hopefully, you'll get the keyboard in the mouse port to work, so you know the port is working. Also, if you have any other PS2 devices that you can test it with.
Good Luck and don't forget to leave a rating based on my solution.
Thanks
Mark
Apr 15, 2009 | ASUS A7N8X-X Motherboard
24-port switch ports not working
try to create 2 comp lan, take both pc in same subnet and connect those to switch.
Mar 15, 2009 | LanTech 24 port 10/100/1000 L2 Managed...
Line in port not woorking
i cant say that i have ever made my Line in port work... try the microphone in port. maybe that will work.
Nov 25, 2008 | Intel DG31PR Motherboard
Did you figure out your KVM?
if you tried to connect your mouse to the keyboard port and still it doesn't work. Power cycle meaning unplug the KVM from the CPU, monitor, keyboard and mouse. Then wait for about 30seconds before reconnecting again. If you still encounter the same problem that the keyboard port won't work then it means that keyboard port is defective. Replace it.
Jul 27, 2008 | IOGear GCS632U 2-port KVM Switch
Staples 2x1 USB Peripheral Switch Logo
63 people viewed this question
Top Staples Computers & Internet Experts
edoco
Level 1 Expert
ray gallant
 steve
steve
Are you a Staples Computer and Internet Expert? Answer questions, earn points and help others
