Question about Hotpoint Washing Machines
Remove fascia panel wmf760 - Hotpoint Washing Machines
3 Suggested Answers
SOURCE: How to change radio on Almera X reg? Does it take a lot of force to remove original fascia panel?
Did a bit of googling and found this site which showed everything in perfect detail.
http://www.fitaudio.com/?View=entry&EntryID=58
Problem solved! Needed a new fascia panel [which I'd had for a while] and wiring adapters for the new radio/cd but these were easy to get from eBay and Halfords.
In retrospect it would have been less hassle just to have got it fitted professionally.
Wife is all smiles now that she can throw her pile of cassettes away.
Posted on May 25, 2009
SOURCE: Stoves E2H600- lighting behind fascia
A bit involved but quite straightforward.
Open the grill door and you will see 4 screws on the underside of the hob - remove the inner 2.
You can now hinge up the entire hob.
On each side of the hob is a trim piece with 2 screws which retain the glass front panel. Remove these and the end trims.
Carefully pull the timer buttons away from the fascia - the simply click into position.
The glass panel can now be tilted up and removed - it is pocketed at the top.
Each of the control knob assembly can then be easily pulled away from the controls.
The fluorescent tube is situated below the controls in a recess.
Rotate the tube through 90° and lift the tube out.
Refitting is the reverse of the above procedure.
Posted on Jun 24, 2011
Remove back bumper from 2004 jeep grand cherokee
  • Raise and support vehicle.
  • Remove wheels.
  • Remove plastic push pins attaching fascia to fuel tank skid plate.
  • Remove plastic rivets attaching fascia to wheel liner.
  • Remove nuts attaching upper edge of fascia to quarter panel and wheel liner
  • Remove plastic push pins attaching fascia to liftgate opening
  • Remove screws attaching fascia to liftgate opening.
  • Remove D pillar trim and scuff plate outboard screws.
  • Remove the rearward tie down screws and the aperture trim panel.
  • Carefully peel back the rubber body sealer patch to access the retainer clips.
  • Release the forward and rearward retainer clips on both sides of the fascia.
  • Grasp forward edges of fascia and pull outward to disengage retainers attaching fascia to quarter panel
  • Separate fascia from vehicle
  • Jul 06, 2017 | Jeep Cars & Trucks
    How do I replace rear parking sensor
    You have to take bumper cover off .
    Remove rear bumper fascia. Refer to Rear Bumper Fascia Replacement . Disconnect electrical from the rear object sensor. Lift the locking tabs on the housing and remove the rear object sensor.
    Preliminary Procedure
    1. Remove the compartment sill plate. Refer to Rear Compartment Sill Trim Plate Replacement .
    2. Remove rear wheel liners. Refer to Rear Wheelhouse Panel Liner Replacement .
    Rear Fascia Push Pin Retainers (Qty: 2)
    Rear Fascia Nuts (Qty: 4)
    Tighten
    10 N?·m (89 lb in)
    Rear Fascia Bolts (Qty: 2)
    Rear Fascia Bolts (Qty: 6)
    5
    Rear Fascia
    Tip
    Energy absorber and fascia are removed together. Cannot be separate on vehicle.
    Disconnect the electrical connectors.
    Dec 22, 2015 | 2006 Cadillac DTS
    I have 'somehow' removed the tension spring that holds my washing machine seal in place... and i cant get it back in place. HELP!!! The model is hotpoint wmf760.
    If you are talking about the door seal spring clip and you have difficulty in getting it to slide back in it's grove use a bit of washing up liquid in the groove and the ring. Is it not adjustable?
    Dec 30, 2012 | Hotpoint Washing Machines
    How do I replace my rear bumper on my 04 pacifica
    1. Open liftgate.
    133387935 Fig. 12
    1. Remove two push pin fasteners per side at the liftgate tower area (Fig. 12).
    2. Hoist and support vehicle with safety stands, as necessary.
    133387936 Fig. 13
    1. Disconnect the park assist wire connector under the vehicle and the push pin fasteners attaching wire harness under the vehicle (Fig. 13)
    2. Remove the four push pin fasteners attaching rear fascia to reinforcement bumper.
    3. Remove two screws (each side) attaching fascia to rear fascia bracket in the wheelhouse.
    4. Remove the screw on each side attaching the upper fascia in the tail lamp bucket area.
    5. Remove rear fascia from vehicle by lifting sides of fascia up and outboard to release from rear fascia brackets.
    6. Place fascia on a clean surface.
    133387937 Fig. 14
    1. Remove park assist sensors, if necessary (Fig. 14).
    133387938 Fig. 15
    1. Remove spring clips attaching upper and lower fascia together (Fig. 15).
    2. Using a trim stick release locking tabs and separate the upper and lower fascia.
    133387939 Fig. 16
    133387940 Fig. 17
    1. Remove move the bright chrome molding from the upper fascia (Fig. 16). Using a trim stick, starting at the out edge of the fascia release the locking tabs (Fig. 17). Grip the molding and pull outward from the fascia while releasing the locking tabs.
    2. Remove molding from fascia.
    INSTALLATION
    1. Place bright chrome molding in position on the upper fascia.
    Jan 06, 2012 | 2004 Chrysler Pacifica
    2011 Dodge Caravan. Ran into a metal wheelchair ramp rain. Drove back - dislodged - the black trim insert near the bottom of the plastic bumper cover. That black plastic thing has to be just put back on...
    Hello Bruce...here are the steps to follow per All Data.
    Release hood latch and open hood.
    Remove the headlamp assemblies.
    Hoist vehicle and support with safety stands.
    Remove the five push pin fasteners attaching bottom of fascia/air dam to radiator closure panel.
    Remove front wheels.
    Remove front wheelhouse splash shields fasteners as necessary to gain access to bolts attaching front fascia to fender.
    Remove the two bolts and two nuts attaching fascia to the front fenders (Fig. 1) and (Fig. 2).
    Disconnect fog lamp wire connectors, if necessary.
    Lower vehicle.
    Remove two bolts attaching the upper grille support to the headlamp mounting panel at each side of the grille.
    Remove bumper fascia from vehicle.
    INSTALLATION
    Position front bumper fascia on vehicle (Fig. 1) and (Fig. 2).
    Install the two bolts attaching fascia to headlamp mounting panel at each side of grille.
    Install the two bolts and two nuts attaching fascia to the front fenders. The fascia should be flush to fender.
    Install front wheelhouse splash shields fasteners.
    Install front wheels.
    Connect fog lamp wire connectors, if necessary.
    Install the five push pin fasteners attaching bottom of fascia to radiator closure panel.
    Lower the vehicle.
    Install the headlamp assemblies.
    The "push pin fasteners" are the pain you are having i believe. They push in, but to get them out you need squeeze them on the back & pull at the same time. If you happen to break a few, you can buy them in various sizes at the auto parts store. I hope this information is helpful, an owners manual will not have any info like this in it.
    Dec 02, 2011 | Cars & Trucks
    How to remove the rear bumper cover on a pontiac 2004 grand prix
    1. Open the trunk.
    2. Remove the rear compartment sill plate. (Trim round the back edge of the trunk)
    3. Pull the left and right compartment side trim panels down to access the fascia bolts and nuts.
    4. Remove the tail lamps.
    5. Remove the fascia bolts and nuts from the rear bumper fascia 1 nut 1 bolt on each side near tail lights.
    6. Remove the push-in retainers from the top edge of the fascia.(4 plastic circles, pull up on center of cirle with screwdriver
    7. Raise and support the vehicle.
    8. From underneath Remove the push-in retainers from the rear bumper fascia (one on each side I think)
    9. Remove the fascia bolts from the rear bumper fascia. on on each side from, up where the facia connects to the quater panel)
    10. Remove the rear bumper fascia from the vehicle
    Apr 14, 2011 | 2004 Pontiac Grand Prix
    I am looking for a diagram of the bumper assembly for a 2004 Chrysler town & country.
    Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
    1. Release hood latch and open hood.
    2. Remove the headlamp assemblies.
    3. Hoist vehicle and support with safety stands.
    4. Remove the five push pin fasteners attaching bottom of fascia/air dam to radiator closure panel.
    5. Remove front wheels.
    6. Remove front wheelhouse splash shields fasteners as necessary to gain access to bolts attaching front fascia to fender.
    Fig. 1 133387737
    Fig. 2 133387738
    1. Remove the two bolts and two nuts attaching fascia to the front fenders (Fig. 1) and (Fig. 2).
    2. Disconnect fog lamp wire connectors, if necessary.
    3. Lower vehicle.
    4. Remove two bolts attaching the upper grille support to the headlamp mounting panel at each side of the grille.
    5. Remove bumper fascia from vehicle.
    INSTALLATION
    1. Position front bumper fascia on vehicle (Fig. 1) and (Fig. 2).
    2. Install the two bolts attaching fascia to headlamp mounting panel at each side of grille.
    4. Install the two bolts and two nuts attaching fascia to the front fenders. The fascia should be flush to fender.
    5. Install front wheelhouse splash shields fasteners.
    6. Install front wheels.
    7. Connect fog lamp wire connectors, if necessary.
    8. Install the five push pin fasteners attaching bottom of fascia to radiator closure panel.
    9. Lower the vehicle.
    10. Install the headlamp assemblies.
    Jan 02, 2011 | Chrysler Town & Country Cars & Trucks
    How do you remove the air filter box on a 2001
    REMOVAL
    Access Rubber Grommet
    Remove large rubber grommet (70 mm x 168 mm) from splash shield to gain access to fascia fasteners.
    Fastener Locations
    Remove fasteners attaching fascia to the front fender and splash shield, using access hole in splash shield.
    Remove Push In Fasteners
    Remove the push pins attaching the fascia to the upper radiator closure panel.
    Headlamp Jack screws
    Remove jackscrews attaching headlamp housing to crossmember and remove the lamp housing to access the lamp(s).
    Roll Fascia Forward
    Roll fascia forward to clear way for headlamp housing removal.
    Disconnect wire connector from back of lamp socket(s) and/or bulbs.
    Remove Headlamp Housing
    INSTALLATION
    CAUTION : Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
    Place headlamp housing into position.
    Connect wire connector to lamp socket(s)
    Verify headlamp and signal lamp operation.
    Install jackscrews to attach headlamp housing to crossmember.
    Align fascia to bumper reinforcement and install the top center push pins, to upper radiator closure panel.
    Align the two fascia studs to the fender vertical attachments, at the same time align the fascia groove on the horizontal flange with the fender drive pin. Push fascia rearward to engage the fasteners.
    Install nut on fascia stud through the splash shield access hole.
    Verify headlamp operation and alignment
    Nov 03, 2009 | 2001 Chrysler 300M
    How do you replace headlamp bulbs on 1999 chrysler 300
    You half to remove the Headlamp housing to change it. Here is the instructions out of the factory manual.
    Tell me if this works for you?
    HEADLAMP HOUSING - CONCORDE/LHS/330M Headlamp lens fogging is a normal condition and does not require service unless excessive or continual. Moisture will vent from tubes or vents located on the back of the lamp.
    REMOVAL
    2. Remove large rubber grommet (70 mm x 168 mm) from splash shield to gain access to fascia fasteners Access Rubber Grommet
    3. Remove fasteners attaching fascia to the front fender and splash shield, using access hole in splash shield Fastener Locations
    4. Remove the push pins attaching the fascia to the upper radiator closure panel Remove Push In Fasteners
    5. Remove jackscrews attaching headlamp housing to crossmember and remove the lamp housing to access the lamp(s) Headlamp Jackscrews
    6. Roll fascia forward to clear way for headlamp housing removal Roll Fascia Forward
    7. Disconnect wire connector from back of lamp socket(s) and/or bulbs.
    8. Remove headlamp housing Remove Headlamp Housing
    INSTALLATION CAUTION: Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
    1. Place headlamp housing into position.
    2. Connect wire connector to lamp socket(s) and/or bulbs.
    3. Verify headlamp and signal lamp operation.
    4. Install jackscrews to attach headlamp housing to crossmember.
    5. Align fascia to bumper reinforcement and install the top center push pins, to upper radiator closure panel.
    6. Align the two fascia studs to the fender vertical attachments, at the same time align the fascia groove on the horizontal flange with the fender drive pin. Push fascia rearward to engage the fasteners.
    7. Install nut on fascia stud through the splash shield access hole.
    8. Verify headlamp operation and alignment
    Mar 27, 2009 | 1999 Chrysler 300M
    How to change lighbulbs behind the panel board of 1998 Toyota Corolla?
    Using a short phillips screwdriver, remove the 3 screws that holds the fascia over the plastic inst panel lens. Pull this fascia towards you, and remove it from the dash. With the fascia out of the way, you will see 4 screws holding the instrument cluster to the instrument panel. Remove the 4 screws. Pull the instrument pod towards you, and, working behind the pod, disengage all of the wire connectors behind the pod. When all of the wire connectors are removed, take the pod from the dash, and look at the back side; the bulbs are accessible there. The bulbs are not special; hope this helps, and THANK YOU for choosing FixYA!
    Oct 21, 2008 | 1998 Toyota Corolla
    Washing Machines Logo
    22 people viewed this question
    Top Hotpoint Washing Machines Experts
    puggy666
    Level 1 Expert
    ptpumpman
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
