Question about YouTube Videos
How to install a fuze wheel writer - YouTube Videos
It typewriter how do I reset it. Ibm wheel writer
Turn off.
, remove a battery, wait 30 sec. turn on, everything will set at default settings, replace battery.
DickyO
Oct 14, 2014 | IBM Wheel Writer 1000 Typewriter By...
How do you make the scroll wheel turn again?
Your wheel may be stuck because dirt has worked its way into the wheel.
I have 3 ideas--
1) Get a can of computer duster, and try blowing the dirt out from around the wheel, outside and inside edge.
2) Sansa Fuze user 'tenzip' suggests dipping the player, while turned off, in DISTILLED water, if you believe the wheel has something sticky and water-soluble-- THEN let it drain, THEN put the player in a bag of uncooked rice for up to a week. The rice will pull the rest of the water out of the player.
Full discussion may be found here;
http://forums.sandisk.com/t5/Fuze/Need-help-How-can-I-open-my-sansa-fuze-mp3-player/m-p/101570#M38972
3) If 1) and 2) fail, you may want to try opening the player, disassembling and cleaning it, and then putting it back together. Directions with pictures can be found here;
http://anythingbutipod.com/2008/03/sandisk-sansa-fuze-disassembly/
Oct 09, 2011 | SanDisk Sansa Fuze MP3 Player
My sandisk sansa fuze has broken its lcd and i cant find any stores here in the philippines that sells an spare lcd for teh sandisk sana fuze.. what will i do?
hi mileeashford, are you still planning to fix your fuze? we have the same case tho the problem with my fuze is the thumb wheel. and i also can't find spare parts in the p.i.
Feb 19, 2011 | SanDisk Sansa Fuze MP3 Player
I just purchased a mp3 and somehow got it in the spanish mode.. how do I get it back to english
1) Turn on your Fuze, and press the Home button (little button to upper-right of scroll wheel).
2) Scroll to the "Parametros" (Settings) menu, and click the scroll wheel to enter it.
3) On the Pamametros menu, scroll down to the last item, which should be "Configuracion del sistema" (System Settings), and click the scroll wheel to enter it.
4) On the Configuracion del sistema menu, scroll down to the 6th item, which should be "Idioma" (Language), and click the scroll wheel to enter it.
5) On the Idioma menu, select the top item "English".
Feb 17, 2010 | SanDisk Sansa Fuze MP3 Player
My Son's Sansa Fuze 4gb, navigation wheel is not working.
The switches may require cleaning. Try claning the switches and switch pads.
Jul 15, 2009 | Audio Players & Recorders
IBM personal wheel writer 2, wrong letter is typed
Try code "L" it will get you out or the language mode
DickyO
May 11, 2009 | IBM Office Equipment & Supplies
IBM Wheel Writer 6 font help
Hi:
There is no manual way to change the pitch on any IBM Wheelwriter. If you want a different pitch you need to change the printwheel.
Andrew
May 08, 2009 | Office Equipment & Supplies
My sansa fuze screen goes black whenever i move the wheel or push a button. it comes back on in aprox 5 seconds but as soon as a buttons push of wheels turn it goes black.
I have the same problem.
Only work around I found was installing Rockbox, then in the settings turning off the wheel light.
Seemed guessing cable issue?? once wheel light when out, the screen would come back.
Dec 19, 2008 | SanDisk Sansa Fuze MP3 Player
Sansa scandisk fuze 4mg wheel will not rotate continued
connect your player to the the pc and double click on MY COMPUTER and then you will see a external memory icon beside your cd/dvd drive.Just right click on it and click on format.
Aug 22, 2008 | Audio Players & Recorders
How to fit a daisy wheel to a type writer
This is primarily for the Brother typewriter I don’t know Olympia typewriters. Brother print wheel are contained in a plastic “cassette” and are not that hard to install.
Oct 04, 2007 | Office Equipment & Supplies
YouTube Videos Logo
16 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
