Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tap light on - Tecnik 24 in. TKD795/3 Built-in Dishwasher
Fluval chi aquarium light does not turn off, defective switch how do I repair it?
Much too late to help, I'm sure, but the cheapest fix would likely be to add a simple tap switch.When the tap switch is turned off, it cuts the power off and the light will go out. A tap switch is simply an outlet with a switch fitted. Plug the tap switch into the wall, plug the aquarium light into the tap switch and you're set. They're cheap at places like Home Depot, likely half the price of the replacement switch from Hagen, who makes Fluval. Also a great way to make it easy to turn filters on and off without having to pull the cord from the outlet.
Mar 09, 2013 | Fish
Hp laptop synaptics touchpad light comes on and shuts off pointer
Had this problem before, very annoying! On mine the idea was double tap to disable the track pad and then double tap again to activate it... In reality tapping rapidly in the area around the LED until the LED shut off seemed to work.
In short; double tap the LED to reactivate the track pad. If that doesn't work tap several times in quick succession until the LED turns off.
Dec 18, 2012 | HP Computers & Internet
Industrial building built in '93. They used 277v (coming off one leg of 480v 3PH) for lighting high bay lights. The number on the line taps for pugging in the lights is: LDM2. This plugs into a G1...
Any electrical supply house should have the wire tap connectors. Your new load depends also on the current draw of the existing load, the wire size, and the circuit breaker or overload heaters on the circuit. If the total load is less than the rating of the wire and protection, then yes you can tap in without causing an overload condition.
Jan 26, 2011 | Heating & Cooling
How do i tap into a 2011 buick enclave dome light to add led lights under the dash. I want them to turn on when the dome light goes on. Where would I find the positive wire for those lights
The easiest place for you to tap the Dome light power would be at teh fuse panel where the fuse is located. The ground for that to work is the little switch in teh door jam near the hinges. The problem you may run into is the dome light coming on when you activate the switch to turn those LED lights on. Your going to tap the power wire direct and put the switch to turn them on controlling the ground unless you want them to work at the same time the dome light does in which case I would tap the power line direct and then run an additional wire to tap the switch in the door. A better option, at least to me, would be to tap power off the lighter circuit and control that with the switch then you could ground anywhere you have a good ground.
Oct 27, 2010 | 2009 Buick Enclave
Cant get internet
First, make sure you have wireless internet, than go to system settings. than internet.
For AOSS: tap connection settings tap a connection labeled none tap AOSS  press the AOSS button on the access point until the AOSS light flashes tap ok to preform a connection test
For access point: tap connection settings tap a connection labeled none tap search for an access point tap the desired access point (note: if you are using a secure access point, enter the key and tap ok) tap ok tap ok to preform an connection test
Apr 23, 2009 | Nintendo DSi White Console
My ambinent light is blinking on my hp touchsmart. the button on the left on the computer turns the light on and off and has three settings. currently, it blinks through all three settings then turns off...
sounds like either the switch controlling the light is not working or the or the abient light is burnt out causing a short. If under warranty Have this check out by an Hp Tech.
Apr 01, 2009 | HP TouchSmart IQ770 PC Desktop
Wiring connections for Kichler 900w transformer
You need to connect one wire from each cable to one of the com terminals. The other wire from each cable has to connect to a tap terminal. The tap terminal you use will depend how many lights and the length of the cable. For short cable runs like 25' use tap 1 50' tap 2 100' tap 3 more than 100' tap 4. you may need to connect all three cables to the same tap terminal. If you turn it on and one string of lights is dimmer than the others move the tap connection from that wire to a higher number. The tap terminals send out a little higher voltage the higher the tap number. The obect is to get the same light output of each light compensating for the voltage drop of the cable. This is a lot of info so I hope this answers your question. If you need more help let me know.
Nov 02, 2008 | Kichler TRANSFORMERS - PROFESSIONAL SERIES...
How do i reset the abs, brake light
If you tap the light with a ball-peen hammer it will go off. Start with a light tap and increase the force with each tap. It will eventually go off.
Sep 20, 2008 | Chevrolet Malibu Cars & Trucks
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
16 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
