Question about Kenwood Car Audio & Video
Output kdc mp5036u - Kenwood Car Audio & Video
Kenwood 252u no audio
Have you tried hooking up a test speaker that is not installed in the vehicle to see if the outputs work correctly?
Jan 10, 2013 | Kenwood KDC-252U
I have a Kenwood kdc-mp342u car cd player installed in my truck. I have subs hooked up to it and everything was working fine until i had to reset my radio and when i reset it the "sub Level...
Subwoofer output: Hold the (AM-) button down for at least two seconds. You can do this function when "SWPRE" in is set to . The SWPRE (Switching Preout) Switches the preout between rear output ("R") and subwoofer output ("SW").
Nov 10, 2010 | Kenwood KDC-MP342U Car CD Player
Cant get the protect mode of its a kenwood kdc-mp142
you probably have a bad output ic then, and it needs to be repaired professionally.
Apr 14, 2010 | Kenwood KDC-MP205 CD Player
What is output impedance of KDC-S2009?
4ohm is what they test them at
Feb 13, 2010 | Kenwood KDC-S2009
The screen on my KDC-MP342U just blinks with the word PROTECT
first, check your speakers and speaker wires for shorts, then disconnect power to the radio for a few seconds and reconnect it. if that doesn't work, then you probably have a bad output ic.
Dec 03, 2009 | Kenwood KDC-MP342U Car CD Player
My kdc 419 sound drops out? is it overheating
most likely a bad ground connection or to much output to your speakers look into a small amp for the speakers
Nov 03, 2009 | Kenwood KDC-319 CD Player
My kenwood flash protect after i reset it
sounds like it could be either a bad speaker, a shorted speaker wire, or a bad output ic inside the deck.
Oct 23, 2009 | Kenwood KDC-135 CD Player
Will the Kenwood KDC 1032 RCA outputs work with an ipod adapter similar to an aux output? If so, how?
Hi, if you are trying to get your I-pod to play through your car stereo, then you would need to have the RCA inputs, not outputs. If you connect your i-pod to the stereo outputs it won't work because both things are trying to push sound out of their outputs. If you connect the adapter to the stereo's inputs then it would work.
Aug 11, 2009 | Kenwood KDC-1032 CD Player
Help
hmm... can you scan tracks up and down?are you running it via extrenal amps or useing the speaker outputs from the radio?
Mark
Mar 07, 2008 | Kenwood KDC-X659 CD Player
Car Audio & Video Logo
13 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
