Question about GE 28300EE1
Month and day and hour wrong on all incoming calls even when I reset time.
When I reset the Month, day and time and then I call my home the GE phone goes to a wrong month and day. My month on GE phone shows July 21, 2009 and time is like 12 hrs off. I keep changing to May 20, 2009 and put correct time and when incoming calls comes in my calls show July 21 or 22 2009 example. I have talked to my phone service people and they say it is the phone but all my other cordless phones which another one is AT & T and it says July 21 etc 2009 also on incoming calls. My phones will not show May 2009. Last correct date was May 15, 2009 on my CID.
  • 201 Answers
SOURCE: Ge cordless 900 mhz home phone
What is "Bell" and "Cogeco"? Did you change phone line provider companies? If so, you would need to ask them if it's possible to change. You are getting the information they are sending you. I do not believe the information is being altered by your phone.
Posted on Jul 07, 2007
  • 201 Answers
SOURCE: brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
SOURCE: ge cordless phone station 2 shows unavailable
You have to register the hand set in the main base. Place each handset in the base for 15 seconds minimum. It will change form unavailable to Ready when it grabs the signal from the base. If the power goes out, you will have to re-register each hand set in the base before you use them again.
Posted on Jan 15, 2008
SOURCE: GE 25931 Cordless Unavailable
I had the same problem recently due to a power outage during a storm. GE advised to disconnect the power cord and telephone cord on the "mother" unit. Wait five minutes. Then plug it back in.
I placed the "mother" phone back in the base. After the screen flashed on the "mother" phone, I removed it and then put the other two portables in the "mother" base.
This corrected my problem and all is now well.
Posted on Feb 22, 2008
LilBit 4 U
SOURCE: GE 5.8 GHz Cordless Phone model # 25836 EE1-A
Press prog..then hit select and use vol to change time and date..I could figure it out, I am sure it will be a breeze for anyone !!lol Have a grrr8 day !! SpanishMoss001
Posted on Oct 15, 2008
I have a GE Cordless 5.8 gigahertz handset and digital answerer. I can see the red light flashing during an incoming call, but hear no dial tone and no ringing. I just replaced the battery. The handset...
Did you pay the Bill ?
this seems as if it,s incoming calls only. Check the line with an alternative Phone. This will verify the lines good. And eliminate that One.
Also check if theres A Tone/Pulse setting.
This can also have adverse effects.
If this is on an adaptor fitting with internet access, try removing the adaptor, and plugging the phone direct into the Socket.
Or try the phone on a seperate or diferent Socket.
Hope This helps.
Mike @ compurepair.
Mar 05, 2008 | Lands Phones
I have this cordless phone with answering machine built in is there any way to check outgoing calls on it made for that day?
Unfortunately this phone system doesn't have outgoing calls log, you can use redial to see only the last dialed number, for incoming calls the system provides a 40 records log, for more details you can see and download its user manual at the link below:
http://www.home-electronics.net/ge/pc/IB/25952EE1_IB.pdf
Mar 05, 2011 | GE 25952 Cordless Phone
Machine will not answer to take a message
You can download the manual at
http://www.home-electronics.net/ge/pc/IB/28112EE2_IB.pdf
Apr 03, 2010 | GE 28112EE2 Digital Answering Machine
Doro 80
If you get caller ID, it will automatically set the caller id on an incoming call Otherwise: Press the OK/Menu button scroll to DATE/TIME using the up and down arrows, then press OK Enter Month (01-12) press OK Enter Day (01-31) press OK Enter hour (01-12) press OK Enter Minutes (01-59) press OK scroll to AM/PM using the up and down arrows press OK to save settings
Jun 08, 2009 | Lands Phones
Phone won't ring in sleep mode
I had the same problem with my iPhone the only way I was able to fix it was to re-flashed the latest 2.2 firmware. Power phone off, power on by holding power and home at same time, hold power for ten seconds and then release still holding home key for another 30 seconds to put phone in DFU mode. Then plug into iTunes it will detect phone in recovery mode and allow you to re-image
Jan 08, 2009 | Apple iPhone 3G Black Smartphone
Purchased 2 ge phones model 29585 installed and ok for several days.now when picking up receiver to dial out we get a pulsating busy signal for a few seconds and then the dial tone and are able to dial,...
That sound is notification of voice mail. This phone does not disconnect incoming calls on answering machine extension so your phone is actually off the hook for hours without your knowledge.
Jul 29, 2008 | GE Lands Phones
Setting the time
At extension 1
press Program (mute light turns on)
press Transfer (mute light flashes)
dial "38"
enter 2 digit year, i.e. "08"
enter 2 digit month, i.e. "05" = May
enter 2 digit day, "01" = first of the month
"31" = last day of the month
enter 1 digit day of the week
1=Sun, 2=Mon, 3=Tue, 4=Wed, 5=Thu, 6=Fri, 7=Sat
enter 2 digit hour in 24-hour format
00=midnight
01=1 AM
13=1 PM etc
enter 2 digit minute from "00" to "59"
press MUTE.
You will hear a single confirmation beep. If not, you did something wrong. Start again from the top.
Nov 29, 2007 | TMC M4810 NON-KSU Corded Telephone
Ge 25952 5.8ghz twin cordless
The day and time need to be reset. The phone has day, hour, and minute buttons on the back. Hold the button down to change to the correct setting and it should solve your problem. You can also go to www.ge.com/phones and pull up a copy of the instruction manual.
Good Luck!
Nov 14, 2007 | GE 25952 Cordless Phone
GE 28300EE1 Logo
65 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
