Question about TruTech PVS31170S1W 17 in. LCD Television
In tv mode tv shuts off message in upper right screen 100-140
In tv mode power goes off message in upper right screen read 100-140
  • 2,005 Answers
Overheat temperature failure check for fan not removing heat
Posted on May 20, 2009
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
I was given an older Sony TV Model KV-27510. It works fine but when watching TV, the Channel number stays on in the upper right corner of the screen. (in this case #3 since I have cable) When watching a...
some tvs are set to hotel mode if they were bought for this and can have the channel number on all the time , you may be able to remove this using this manual. https://docs.sony.com/release/KV27S10.PDF it may help you to read this to remove it.
Jun 30, 2017 | Sony Televison & Video
The tv does not stay on when turned on goes off right away
This TV decided there is nothing of value to watch << Just kidding, could not resist...
Is there any message? If you do not have a signal to the port that the TV is set to, many will go into standby mode, but there is a message. This is a bigger problem with Blu Ray, as the machine takes forever to start up and there is no output signal during the start up, so that would cause the TV to go into standby mode (shut down).
Jul 23, 2011 | Philips 42PFL5332D 42 in. LCD Television
How to shut down a computer?
1. Close any applications you have running, such as your email or instant messaging service, by clicking the "X" in the upper-right corner of each program page.
2. Left-click your mouse on the Start button, typically found in the bottom-left corner of your computer screen.
3. Highlight the option to "Shut Down" and left-click your mouse again to initiate the proper shutdown process.
4. Wait until your computer logs you off of any applications, your computer screen goes blank and the power light turns off before you turn off your monitor or close your laptop.
Dec 23, 2010 | Computers & Internet
External monitor says laptop is in power save mode and goes blank
hey jkep
this has nothing to do with power, here is what to do
right click your desktop->
properties->
click the settings tab->
click the advance button->
click the display tab->
depending on your graphic card there should be 2 or 3 different monitors being displayed switch them on and automatically your TV will turn on then you can change the settings to your likings
Feb 13, 2009 | Acer Aspire 5610 Notebook
Canon imageRUNNER C2058 color network printer board-B1 only. Upon power up the display screen indicates "Wait...".
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
Jan 25, 2009 | Canon imageRUNNER C2058 Led Printer
Diagnostic Mode?
Press and hold power & action button on front of tv hold untill tv turns off release - Set will come back on with other menu just press channel up . this should clear setup mode.
Nov 18, 2007 | Panasonic PT-51HX40 51" Rear Projection...
ERROR MESSAGE READS...
Try starting it in safe mode. (Hold F8 after power on). If you get your icon screen go to start, run and type in msconfig. Click startup and disable all the items. Hit OK and try a normal restart. This error can be caused by a bad program starting up.
Aug 30, 2007 | IBM ThinkPad 600X Notebook
TruTech PVS31170S1W 17 in. LCD Television Logo
49 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
