Question about Refrigerators
I have model # PSC23SGMD the freezer seems to be working OK but the refer side is to warm and wont cool down,plus the post between the doors gets hot.
  • fdaveou8122 May 21, 2009
    Hello Sea Breeze,
    I took the motherboard out and there are no burn marks,and yes the coils had some frost on them they were not really iced over but they were covered.
  • Refrigerators Master
  • 4,654 Answers
Your refrigerator is controlled by a mother board located on the back of the refrigerator inside a covered section about half way up. The reason I mentioned the is thermostat functions on that refrigerator are controlled there. I want you to unplug refrigerator and open that cover and examine both sides for burn marks. During that time also open the back of the freezer wall and see if the coils are frozen over. If yes defrost with a hair dryer and we need to check the defrost element and defrost thermostat. When you get to that point let me know what you find,
Thanks, Sea Breeze
Posted on May 21, 2009
  • 3 more comments
  • John Tripp
    John Tripp May 21, 2009
    OK I hope we find the problem soon, need to unplug if not already unplugged. Inside the freezer with the back panel removed you see the evaporator. On the bottom of the evaporator coil is a defrost element inside a protective holder. Disconnect one wire one the end and check the element with a ohm meter to see if the element shows continuity. At top of the coil there is a defrost thermostat when the temperature inside the freezer the defrost thermostat has contacts inside the open and stop the electricity from going to the defrost element as to prevent the defrost from staying on too long. There is also a temperature sensor on the evaporator coil. Hopefully you may spot the problem soon, but this refrigerator looks like it is going to play hard to get. I have repair manual I need you to get a copy of so you can follow with me. My email is appliancepartsse@yahoo.com I believe the refrigerator you have is related to the GE Profile or Artica. And if we don't find the place visually then we will need to start to run some diagnostics on the board. Below is a link to go to and enter your model number in the model and parts search feature. When you get to the picture of your refrigerator click on the fourth photo down on the left of your screen. That shows the parts you need to test inside the freezer. Email me and I will send the copy of the service manual in PDF format. If you don't have the latest version of Adobe, go to adobe.com and download the free version of the adobe 9. This is going to take a while but you won't need to pay a lot of money for the service guy. I am waiting for your email so I can send you the service manual. Thanks, Sea Breeze
    http://servicepartstec.blogspot.com/
  • John Tripp
    The problem with the heat coming on the post between doors is normal. unless the area is extremely hot. It's a heat strip to keep water from forming around door frame. The refrigerator section has an electric controled duct with a damper inside that adjust the amount of cold air from the freezer. See if you can locate that. I seem to have got on the wrong track, sorry.
  • John Tripp
    If the evaporator coils have a good bit of snow formed around them then the refrigerator section is the first place you will notice the lack of cooling. If this continues it causes me to question if the freeze is defrosting normally. I will wait to hear from you for the next step. Sea Breeze
  • James C Aug 25, 2012
    I am having the same problem. I just fixed a bunch of pipes that had dried out and cracked leaking water on the floor. All main water pipes. When I fixed it though I had left the fridge door open as i was replacing the pipes that go to the water filer and the water reservoir. Once I pieced it all together then suddenly the freezer temp keeps going up to 20 degrees.
  • John Tripp
    John Tripp Aug 26, 2012
    Sorry I did not see your message until today. What happened with your refrigerator is warm moist room air was drawn into your evaporator and quickly frosted over. If yours has the same motherboard it may confuse the defrost and you will continue to have cooling problems until you unplug and allow enough time for your evaporator to defrost without power and doors open. If you have problems contact me, Thanks JT
If refrigerator is still cooling, but not real cold, could it just use freeon or motor replaced? I paid almost $1,000 on it in 2005. My husband tells me refrigerators are generally made to last 10 years....
Ok
How is the freezer? Everything frozen solid?or is that warm too?\
If freezer seems good ,then you 're gonna be ok.Meaning your compressor is fine , and there is a refrigerant charge. In this case ,you probably have a defrost problem where refrigerator section gets really warm but freezer still works "ok".This is a very common problem.Get us a model # and we can narrow down what it might be.Don't throw away the machine.Easily fixed.
If freezer is not freezing well but there is still refrigeration, the compressor is still probably ok,but there is some inefficiency going on.Most comonly condenser fan off or very dirty condenser coils or bad door seal leak or thermostat system keeps shutting machine off too much.A refrigerant leak would be terminal and you would have 0 refrigeration .
Much to ponder
Repost with more info if you need more help
Hope thi makes you feel better
Aug 22, 2011 | Kenmore Side by Side Refrigerator
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
We have a refridgerator, about 2-3 years old, Model #ED5JHEXTB00. Side by side freezer, refridgerator that is not cooling as much as it should in the refer part. I'm not sure of the temp, but milk goes...
if your noticing frost on the back wall you have a defrost problem and need to address it immediatley before u get warm in freezer and refrigerator sides remeber that a refrigerator is just a cold air duct from the freezer.... defrost heater bimetal defrost thermostat ot timer defrost control is bad ...
Feb 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE bottom freezer model PDS22MBRBWW gets too warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE Profile PDS22SBRR Stainless Steel...
Only the freezer side is working
I don't think the darkness is related to the fridge not being cool. The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Fridge not cooling
Hello.
The first thing you need to do is take out the bottom drawer in the freezer and look into the slots in the back panel. Make sure that you can see silver coils, and not a bunch of frost. If there is, then you need a new defrost timer, defrost heater, or defrost terminator.
If all looks ok then make sure the fan in the freezer is running. (You may have to push the door switch if yours has one.) If the freezer fan isn’t blowing however, the freezer will be warm at the top and cool at the bottom, and you fresh food compartment will be warm.
Another thing to make sure is that the light it turning off when the door is closed. Again you would have to push on the door switch. I was amazed to learn when I first started this line of work, that even a little light bulb can make enough heat to cause a problem.
These are the most common issues.
Let me know if everything looks ok and I will go over some other things, as the list of things that can go wrong with a refrigerator is fairly long.
Dec 07, 2008 | Refrigerators
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Leak from icemaker shorts electricity in house
It sounds like the ice in the bin is warming up enough to melt for some reason then re-freeze. Check your door gasket seal and also the ice chute door flapper seal to make sure warm room air isn't being drawn into the ice bin area. Also make sure the freezer area is VERY cold like 0 degrees F or lower, that will keep the ice hard and help stop the ice from having a liquid surface film from opening and closing the freezer door too often (then freezing again). The water down the back is from the ice cubes melting a little then re-freezing. Also, is the frige working OK? Does the compressor turn on and off normally? I ask because sometimes the compress start device is failing and the refer can warm up quite a bit while the compressor is trying to start up... eventually the compressor will start but by then the ice has melted a little then the compressor runs for a long time to bring the temps down again. Monitoring with a thermometer every hour will show if the temps are lowering in the freezer section too much.
Dec 10, 2006 | Maytag MZD2669KE Side by Side Refrigerator
Refrigerators Logo
436 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
