Question about Dishwashers
I need to correctly connect wires on FSP 3369325
Kitchenaid Dishwasher Model #KUDS25SHW1, Serial #FK2253394. The Microswitch FSP 3369325 (V7-1C29E9-000-1) has been replaced and the two wires, one black in color and one tan in color need to be correctly re-attached.
  • 726 Answers
SOURCE: We need to replace the
i searched it up and you only have to change the actuall latch
Posted on Jul 06, 2008
SOURCE: Asko Superior 1473-262 Dishwasher
the brown wire mounts toward the front of the dishwasher, and the green wire to the back spade
Posted on Jul 24, 2008
jsrock516
  • 5911 Answers
SOURCE: KitchenAid Dishwasher (model KUDS01IJBL) has black gunk inside
That black gunk is caused by soap deposits and food particles that do not get washed down the drain. This all collects in the area around the door gasket and front of the wash tub and forms a sticky black sludge. You need to periodically clean the interior of the dishwasher out with a non-abrasive cleaner with some bleach in it to kill bacteria. You should also check the wash pump sump (located under the lower spray arm) to make sure it is not being clogged with food and debris. In order to access the pump sump, you will need to perform the following:
1. Remove the lower wash rack and lower spray arm.
2. Remove the upper wash rack and spray arm.
3. Locate the screws holding in the upper spray feed tube. Remove the screws to the feed tube and turn the whole assembly 1/4 turn to the right (CW direction). The entire assembly will unlock from the wash pump assembly and lift out.
4. Remove the strainer assembly (known as an accumulator) that covers the pump sump area.
Inspect the sump area for food particles and debris that may be contributing to the mess inside the wash tub. If you need some guidance, pcappliancerepair.com has some very helpful exploded view diagrams to assist you.
If you have any questions, or require further assistance, please let me know. I hope this is helpful to you.
Posted on Aug 17, 2009
  • 43 Answers
SOURCE: i replaced a fsp dishwasher motor but
new motor should have a diagram,normally on the cover to the terminal block,or wire connection area.you may need to consult seller of new motor.
Posted on Oct 16, 2009
aborcass
  • 2651 Answers
SOURCE: Remove the Impeller on the motor of dishwasher
you can acess the impeller, by removing the lower spray arm, ther are 5 torx scrws holding the motor cover down, then from ther ther are 2 additional torx 15 screws covering the pump outlet and impeller housing, the impeller is spring loaded in place.
Posted on May 18, 2010
I just installed my kitchen aid dishwasher model kudco03fvss and it won't drain. There is standing water in the bottom of the dishwasher. It is a brand new appliance. There is no water going through the...
Hi, my name is Audrey. I am a KitchenAid employee and thought the following link might help address the draining issue you're having with your dishwasher:
http://kitchenaid.custhelp.com/app/answers/detail/a_id/84/kw/not%20draining/session/L3RpbWUvMTI4ODEwNzU5Mi9zaWQvOVEyalRzZGs%3D
If I may be of further assistance to you, you may send me an email through our customer service address,
KitchenAid_CustomerExperience@KitchenAid.com
and type 'Attention: Audrey' in the subject line. Please include your full name and model/serial number, and I would be happy to try to help resolve the situation with your dishwasher.
Oct 25, 2010 | KitchenAid KUDC03FVSS 23 in Builtin...
Blown fuses
Hi
You can get the manual for your kitchenaid dishwasher from this link---
Kitchenaid Kuds01dlss Dishwasher Manual
Please post back for any further assistance.
Daniel
Jul 22, 2010 | KitchenAid 24 in. KUDS01DLSS Built-in...
Kitchenaid dishwasher is leaking
depends. take the lower panels off the dishwasher below the door right at the floor. Once this is done you will need a flashlight. If possible lay on the floor with the flashlight and activate the dishwasher. Look for the leak at that point. If it starts leaking in the drain cycle then the impeller is leaking and will need to be replaced. These can be a little pricey so take the model and serial numbers and call an appliance parts house for the cost and it is a little bit of a hassel to replace so only you will know if you want to tackle it yourself or buy a new dishwasher. If is leaking during the rinse cycle then the gasket at the base if the washer (where the motor connects to the dishwasher itself) has gone bad and this is a bugger bear to repair. So it's up to you if you want to repair or replace.
Good luck on repairs Hope I helped you some
Dr Berry
Feb 17, 2010 | Dishwashers
Seeking the manual for an old Kitchenaid dishwasher model KDS-17 serial no. 220-2691847 Any help will be much appreciated. My email aryamani@yahoo.com
kitchenaid didnt make that d/w, hobartmade it for kitchenaid, thats why they are still running from the 1960's the mod# from hobart should be a wm5h
Oct 26, 2009 | Dishwashers
I replaced a fsp dishwasher motor but dont have the plug for it. which wires go to which of the four spade lugs on the new motor?
Oct 16, 2009 | Dishwashers
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140, THE DISHWASHER IS NOT RESPONDING TO ANY COMMANDS, THE RINSE LIGHT IS BLINKING AND THAT...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140. The unit is not drying the dishes?
Oct 02, 2009 | KitchenAid Dishwashers
Wiring diagram for electric motor, FSP PArt Number 3369330
why would you want to? if the motor is reversible the details are inside the little plate cover of the motor where you wire it in!
Mar 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
No power
look in the control panel the door will need to be dissasembled there is a fuse in the control panel it is mounted to the side of the control its self is is actually cliped onto the black portion of the control check the fuse with a meter if it has blown then replace it 675796 or 675813 is the part number you will need it will be written on the old part it will say fsp???????
also check the wiring from the house to the dishwasher for a loose connection this can cause the fuse to blow
Apr 13, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Dishwashers Logo
Top Dishwashers Experts
