Tivoli songbook antenna - Audio Players & Recorders
3 Suggested Answers
SOURCE: My black Tivoli Songbook case
Hi Jodi:
Same with both of mine. I used solution of vinegar and water, about 50/50. It seems the "rubbery" texture is now gone, but the terrible sticky is gone also. The solution did not remove any of the lettering or numbers.
Moose in Phoenix
Posted on Jan 25, 2011
SOURCE: tivoli radio sticky case
I have the yellow songbook and it was so sticky and dirty after only a couple of years. I only use it inside, so I removed the sticky coating with nail polish remover and a ton of cotton balls. It worked really well on the yellow one - the finish is a little dull so it matches how it looked when it was new. And it's so clean now!
Posted on Nov 20, 2011
SongBook potentiometer
This can be replaced by a generic control and should be available from any electronics parts supplier. There are two main types of these that differ only in the way they are mounted. When you look for the replacement, you will need to specify the direction of the pins. In other words, are the pins inline with the main shaft or are they at a right angle. Since you are in Italy, I don't know any distributors there, but this should be a common enough part to be found just about anywhere. The indication A20K indicates that this is an Audio Taper valued at 20K which is 20,000 ohms.
Good luck.
Dan
Apr 16, 2008 | Tivoli SongBook FM Radio
Hello, I purchased a Tivoli Model One few months ago and I noticed that after tuning a radio station (strong signal, amber light on), the signal will fade out in ten minutes or so and I need to tune it...
hi,
it looks like its got a hookup for an external antenna on the back, hook a wire to it or better yet hook it up to a pair of rabbit ears, look at the back and make sure your hooking it up to the right connector am/fm
rabbit ears at walmart
..jm
Tivoli Audio Frequently Asked Questions Tivoli Audio
8260f424-51e7-404b-8aad-55d32a5ee6ab_1.c6ade34e7d92de1dbfde961d78f8c87b-2mys2t2nr3la4vnxyourkcko-2-0.jpeg
Jul 13, 2017 | Tivoli Kloss Model One AM/FM Radio
I have a Tivoli Ipal and I have a broken antenna. I have a new replacement antenna but need to install it. help.
Bought a replacement antenna for my iPal for about $5 plus a couple of dollars shipping. Installed it in 5 minutes without taking the back off of the radio. No big deal. Simple, cheap, fast.
Jan 20, 2011 | Tivoli iPAL AM/FM Radio
Can't seem to tune many stations at all. Also once a station is tunned it "slips".
The antenna works with the power cord. Try extending the length of its power cord with an extension cord.
Position of the radio in the room, the furniture in the room and your position in relation to the radio all affect its reception.
If there is a place to connect an external antenna, this will be helpful. Check with Radio shack and best buy for a FM loop antenna. Usually the wire is flat.
An inexpensive antenna for FM only is also a cheap alternative
Jan 03, 2011 | Tivoli Model Three Clock Radio
My black Tivoli Songbook case has become completely sticky. I have only ever used a bit of water and a cotton cloth, what can I do or clean it with? thanks Jodi
Hi Jodi:
Moose in Phoenix
Oct 31, 2010 | Tivoli SongBook Clock Radio
Tivoli radio sticky case
Apr 09, 2010 | Tivoli SongBook Clock Radio
Antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Jan 06, 2009 | Tivoli (PAL) AM/FM Radio
18 people viewed this question
 Grubhead
Grubhead
