Question about Precor Efx 5.17
5.17 noise Noise motion
The e t c is buzzing what is causing this
ANSWERS: Oil Loss, Buzzing Noise, ETC. - Nissan Forum ' Nissan Forums
forums.nicoclub.com/answers-oil-loss-buzzing-noise-etc-t323273.html
Mar 20, 2008 - 3) Yet another buzzing, rattling or whinning noise. If you own a Quest van, Maxima, Altima 3.5 and some Z/G/FX vehicles, and get a loud ... Mysterious no-spark situation with a buzzing transmission
Mar 31, 2013
ABS brake fault light on, buzzing sound
Feb 7, 2011
ECU making loud buzzing noise
Oct 6, 2009
Buzzing noise under the hood towards the back of the engine ...
May 8, 2008
More results from forums.nicoclub.com
Buzzing noise at 2000-3000 RPM - Nissan Forums : Nissan Forum
www.nissanclub.com/...nissan-altima.../128490-buzzing-noise-2000-300...
Oct 28, 2003 - 6 posts - ‎3 authors
The "buzzing noise"; I can tell that I am not alone in having this problem but has someone figured out ... I fit does, that eliminates the brake rotors, tires, wheelbearings, CV's etc. ... BUT with an Altima it is probable the pre-cats. Loud humming noise when driving
Aug 29, 2009
Noise when accelerating
Jul 21, 2009
engine noise/whine - 05 3.5SE
Nov 17, 2006
My altima has a humming noise under my hood
Jan 17, 2005
More results from www.nissanclub.com
Jan 05, 2016 | 2000 Nissan Altima
Mustang gt 5.0 inside passenger side car in motion auto trans in drive or neutral, knocking noise heard from transmission area
check your torque converter bolts/nuts.
and if it ONLY makes the noise when it's in neutral or drive NOT moving I'd suspect a front pump torque converter. You can unhook the torque converter to isolate this diagnosis... If it ONLY happens when the vehicle is in motion you might be looking in the wrong place
Oct 27, 2014 | Ford Mustang Cars & Trucks
Why is the Precor AMT 100i Adaptive Motion Trainer Elliptical primary belt making noise and should I adjust it?
SOmetimes belts make noise when they are worn out and need to be replaced - belts like that are considered 'wear' items, like tires on a car - they have a very limited lifespan compared to the other parts.
Jun 18, 2014 | Precor AMT 100i Adaptive Motion Trainer...
2004 dodge intrepid front end noise
Without a description of the noise, this is impossible to diagnose. Common problem with these vehicles is a "grinding" type noise. This will be a bearing that has gone bad or brake pads that are beyond the service life (louder screeching or grinding upon braking). Popping noises are the CV drive axles are bad (noise is typically louder when when the vehicle is in motion and turning).
Jan 31, 2014 | 2004 Dodge Intrepid
Calabrations settings for 40es6100
Try this:
Picture Mode Movie
Backlight 16
Contrast 95
Brightness 45
Sharpness 15
Color 50
Tint G50/R50
ADVANCE SETTINGS
Dynamic Contrast Off
Black Tone Off
Flesh Tone 0
RGB Only Mode Off
Color Space Auto
10pt White Balance On
Gamma +1
Expert Pattern Off
xvYCC Off
PICTURE OPTIONS
Color Tone Warm2
Digital Noise Filter Off
MPEG Noise Filter Off
HDMI Black Level Low
Film Mode Off
Auto Motion Plus Off
LED Motion Plus Off
10PT WHITE BALANCE
ON
Interval Red Green Blue
1 0 -1 -1
2 -1 -1 -1
3 0 0 0
4 -1 0 +1
5 -1 -1 +1
6 -1 -1 -1
7 -1 -1 -1
8 0 0 0
9 +1 0 0
10 +2 0 0
WHITE BALANCE
Setting Value
R-Offset 25
G-Offset 25
B-Offset 28
R-Gain 18
G-Gain 23
B-Gain 21
SCREEN ADJUSTMENT
Picture Size Screen Fit
Sep 03, 2012 | Samsung Televison & Video
Front end has a noise like brake shoe rubbing the rotor
A few things could be the problem. Are you certain that you don't have a small rock jammed somewhere and that's what's rubbing? If the pads are down to the sensors, that would start making a squealing noise. The pads will still show lining on them when the sensors are starting to touch the rotors.
Aug 04, 2017 | 2006 Ford Freestyle
SyncMaster 793DF 17" CRT Monitor: monitor makes high pitch noise...
With a piece of wood or plastic hit the flyback with the monitor turned on. If you note some change in the noise. Replace the flyback.
Normally, it is the cause of the noise.
Warning: High Voltage!! Do at your own risk!!!!!!
Best regards,
May 16, 2010 | Samsung SyncMaster 793DF 17" CRT Monitor
Sporadic shriking noise when in motion at lower
Either a brake pad or the fan belts !
Lube the fan belts with candel wax or silicone spray, if the same noise, it is a brake pad !!
Aug 16, 2009 | 2007 Hyundai Santa Fe Limited
Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
Pride jet3 makes noise when engaging forward motion
Sounds like your motors are gong out. You`ll need to get to a reputable dealer for further diagnosis.
Mar 28, 2009 | Pride Mobility Products New Pride Mobility...
Precor Efx 5.17 Logo
24 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
