Question about Saniflo & Saniplus& Macerator Pump
Toilet noiserumbling noise - Saniflo & Saniplus& Macerator Pump
Dirty Water in toilets, gurggling & spitting sounds
Are you on a well or city water? Septic tank shouldn't matter as it is below the level of the water in the toilet. It is coming from the fill water.
Jun 02, 2012 | American Standard 2860.334 Enfield Two...
I have a saniflow for toilet and when flushed it makes a whirring noise and gradually goes to a loud crunching noise at this point i turn power supply off when turned back on its ok till next flush !p
find water pressure regulator. it will have a bolt coming out of the top with a nut at the base of it.loosen nut. while toilet is being flushed, adjust bolt till noise stops. turn bolt clockwise to adjust.
Dec 17, 2011 | Taylor Home
Handle is sticking in one toilet the other toilet makes a loud whisteling noise after flusing
The handle is probably worn out on the first toilet. The whistling on the other toilet is probably from a restriction in the fill valve, if you can live with whistling, it's not really a problem. If not, I recommend trying a different type of valve.
Aug 09, 2011 | Toto Home
Every 15 minutes toilet float makes noise as if going to flush then goes away and makes noise every 15 minutes for about 10 seconds as if it is going to flush but does not and returns to silence but does...
The toilet flapper valve is slowly leaking. When the water level drops sufficiently this opens the fill valve to bring the level back up. This is all controlled by the ball float. A simple solution is to buy a new toilet flapper valve for your brand of toilet.
Watch this video for clues on how to clean and replace:
Dec 11, 2010 | Computers & Internet
The toilet keeps running constantly - the tube in the tank is overflowing and i can not get the dripping sound to stop. Anything i can do?
The noise is because your float in the toilet is set at too high of a level and it is overflowing and making noise.
Reset your float, to adjust the water level just below the overflow pipe...this should stop your noise.
If it does not correct the problem then you will have to replace the water control unit inside of the toilet tank.
Please rate me
Dec 05, 2010 | Toto Washlet Elongated Toilet Seat Bidet
Toilet drains to a certain level every half hour then refills with a sqeaky noise,when flused it makes a very loud sqeaky noise.
May need to replace toilet flapper or entire flush valve. water is getting from the tank into the toilet which is causing this to happen.
Aug 31, 2010 | Toto Aquia II Dual Flush Toilet
We just installed a new one piece toilet from Neptune. It makes a loud noise when you flush it and after the water fills up. In addition, if you flush another toilet or turn on the washing machine it also...
Hello. I doubt that the installer would not install it properly. That said, the issue you are having makes me wonder if your bath drain plumbing is properly vented to the outdoors through the roof. Joe
May 07, 2010 | Neptune FB1602 Roma Elongated Front Toilet
My Toto Drake toilet makes a noise like it is gasping for air when the tank is refilling with water. The water flow stops and starts while this noise is being made.
just simply clean the auto switch,the noosle where the water comes out when the floater goes down everytime the tank is empty with water.
Jan 11, 2010 | Toto Drake ADA Compliant Toilet with...
I hear noises and feel vibration from the wall behind the toilet tank. When I lift up the toilet water tank cover or flush the toilet, the noise and wall vibration stops. However, the same noises and...
Your ball **** needs replacement (water control valve), Also your flapper or tilt valve disk is leaking water through it and it needs replacement also.
Sep 09, 2009 | American Standard Toilet Tank ...
Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Aug 04, 2009 | Home
Saniflo & Saniplus& Macerator Pump  Logo
23 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
