Question about Kelvinator Refrigerators
How do i change the light bulb on my kelvinator fridge/freezer
SOURCE: Fridge and Freezer not cold, compressor not coming on
these are 2 different things.check the light switch. also check cold-control, defrost timer, relay on compressor.
Posted on Jul 22, 2008
SOURCE: kelvinator 380 fridge
called the experts....all fixed.
problem- flty sensor terminator
Posted on Sep 05, 2008
SOURCE: How to adjust fridge and freezer doors on Kelvinator C520 Litre
how do you adjust the freezer door on a Maytag side by side 26 cu ft refrigerator?
Posted on Nov 12, 2010
  • 32 Answers
SOURCE: kelvinator fridge freezer, fridge too cold
Fridges that are less then 10 years old have a lot of POWER. To get rid of the frost, wait until you have eaten most of the food up (maybe a few days), then unplug the fridge and leave the doors open. This will take care of the frost after several hours.
From then on, make sure that when your fridge is full, use a higher setting, and when it is near empty or half way full, use a lower setting. Keeping the freezer at a mid to low setting all the time should be fine, because its usually the fridge part that gives people trouble.You will have to judge on your own which setting is best (i.e you can tell when its good based on how cold the juice is in there, etc).
By adjusting the setting based on the amount of food in your fridge, it should prevent frosting.
Hope that helps!
Posted on Mar 28, 2011
  • 403 Answers
SOURCE: I have a Samsung Fridge
Just take the cover off. You can go to your local hardware store or pharmacy like walgreens, cvs and purchase an appliance bulb
Posted on Jul 09, 2011
The light in my Kelvinator fridge will no longer work, can it be fixed, globe has been replaced , also
Barbara: You can remove the globe and replace the light bulb with an appliance light bulb. If it still doesn't work, try wriggling the socket a little bit with the light bulb in place (so you don't get shocked). If it STILL does not work, yes, a socket can be replaced and rewiring can be done.
May 25, 2015 | Kelvinator Refrigerators
My Kelvinator N245C fridge freezer is ok but fridge not cooling when i open the freezer door , the cold air through to fridge air outlet ok but when the freezer door shut and than no air to the fridge the...
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
Nov 01, 2011 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator fridge freezer is a geiger counter
something could have fallen into the fan between the two compartments
Nov 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge not getting cold
unplug unit to "reset." pull unit out from wall and blow the coils out on the back of refrigerator. if that does not work- call service man to come check freon level.
Aug 09, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator F/Freezer not working. Not fuse
Sounds like gas is out.Probably leaking Contact the dealer where you bought it,Should still have guarantee.Jan
Feb 12, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator Inox Freezer not switching off
hi! theres no funny when you smell burning please switch off the power and you che
Jan 20, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge light model unknown
Your best bet is to remove the light bulb and take it to a light bulb specialty store. They will be able to match one up for you.
Jun 21, 2008 | Refrigerators
BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Apr 08, 2008 | Refrigerators
Refrigerators Logo
55 people viewed this question
Top Kelvinator Refrigerators Experts
Charles T Nevin
Charles T Nevin
richie46
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
