Averdigi eb3004 md
How to play back without a remote
How to empty a full hard disk for the eb3004 md
boot with a windows cd/dvd and delete all partitions and then create one and install windows.
Sep 08, 2014 | Computers & Internet
How can I use the Sync Record function without having the remote control available?
It would be a lot simpler to get the remote. Check minidisc.org to find the one you need (most MD Sony MD Decks will do most functions with any sony MD remote) the catch is you need the exact one for stuff like this. You can also check the manual there to try and find a work around but I think you'll need the remote.
Almost any Sony MD remote is available on eBay, the parts houses still carry them but they can ask a lot for them. I recently found the exact remote for my 5CD-->MD deck for $1.99 at a resale ship, it would have been $65. at the parts house.
Jan 05, 2014 | Sony MDS-JE520 Mini Disc Player
How do I connect a usb turntable to a Yamaha HTR 6230? Sony turntable PS-LX300USB preamp switch set to 'line'
hi,
Select the switch to line. Then connect the red and white RCA pins to the corresponding red and white sockets of MD/CD-R play input of Yamaha. Select the MD/CD-R by pressing the button on the remote. Then play the turntable.
OK
Oct 15, 2011 | Sony PS-LX300USB Turntable
Remote is not working
The most likely cause is a problem with the hand held remote. These units use infrared light which the eye can not see. But if you have a digital camera it can! Look at the remote through the view screen of the camera while someone pushes buttons pointing at you. If it is working you'll see a pulsing light. if not change the batteries or try a universal remote.
May 08, 2010 | Avermedia AVerDiGi EB1304 Net
Kenwood MD plays ok but recordings fail to play; U TOC error?
Without a decent Table Of Contents, your MiniDisc will NOT work, as you've found out. Does it matter what brand of MD you use? I would record it at "1X" and NOT 4x speed too. Try erasing a blank minidisc first and then shut off the unit and then turn it back on and see if the TOC works. Try adding a title, then turn it off and back on. Then try the CD to MD.
Jan 16, 2010 | Audio Players & Recorders
RTs00c00e00 ERROR MESSAGE, WILL NOT PLAY TURN OFF OR EJECT. TRIED TURNING POWER OFF AND UNPLUGGING, SAME ERROR MESSAGE COMES UP. PLEASE HELP! NOT IN MANUAL.
I just turned on my Sony MDS-JE520 and got the same error message RTs00c00e00. Didn't wanted to play MD, but did throw out the MD. After turning it on and off still got the same message. When I took the remote and pressed the key display, it came back to the normal "mode". Everything works again, so hopefully it stays with only this one-time incident.
Hope it will help you guys also.
Regards, Danny
Nov 23, 2009 | Sony MDS-JE330 Mini Disc Player
Is their an aux function for a sony cmt-ne3
What if I no longer have the remote?? Is there another way of accessing the MD or "aux"??
Nov 13, 2009 | Sony CMT-NE3 CD Shelf System
TEVION 8 IN 1 REMOTE CONTROL
http://www.fascin8.co.uk/support/1695.pdf
May 18, 2008 | Televison & Video
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
