Question about Dell Vostro Computers & Internet
Cpu overheating CPU 540 1.86GHz overheating
  • Dell Master
  • 9,639 Answers
The cooling fins on the processor chip are plugged with dust. The fan may not be turning fast enough. If that's the case you'll need to replace the cooling fan
Posted on Jan 15, 2016
2 Suggested Answers
  • 6771 Answers
SOURCE: cpu overheat
If the cpu is overheating the cooling fan may need to be changed, chances are the laptop will need to be taken apart and cleaned. A can of compressed air is ideal for blowing the dirt out of the heatsink and fan, also! removing the old thermal paste from the processor and heatsink and applying fresh compound will make all the difference.
Posted on Jul 03, 2012
Error 17
"Initialize cache before memory autosize"
This is the cache in the CPU.
The most common cause of this error is the CPU has been overheating.
Check the airflow.
Overheating can destroy the CPU.
Mar 19, 2014 | Tyan S5397WAG2NRF Dual Lga-771 Xeon Ddr2...
Tip
CPU is overheating
Either CPU is faulty, or the heatsink has lost aderence with the CPU surface or cooling power.
Standard procedure is refitting or replacing cooling fan, in some rare occasion is the CPU, but that is uncommon and can't be tested.
Another possible cause is the temp sensor on the motherboard that is faulty.
first ensure that is overheating and check temp sensor using SpeedFan - Access temperature sensor in your computer.
on Aug 09, 2009 | AMD Athlon 64 X2 5200+, 2.6 GHz
Error 17
Check the airflow.
Mar 19, 2014 | TYAN S5397WAG2NRF Dual LGA771 XEON DDR2...
CPU throttling
I would like to start by saying that this is not a good idea on a laptop. CPU throttling was designed to conserve battery life and save your processor from overheating. Laptops are not designed for gaming they are designed for mobility. That being said, turn your laptop on press F2 at the Dell screen to enter setup (a.k.a. bios) then if your bios supports you disabling CPU throttling you will find it there. Intel has done a great job with this CPU feature and your CPU will give you the performance you need when you need it. I work on computers/laptops and I have never disabled CPU throttling I have replaced a few processors that have overheated because someone disabled throttling though.
Feb 27, 2013 | Dell Latitude D630 Notebook
Laptop overheating, need to remove the back casing.
Most laptop having high temperature. Use notebook cooler and place it under the laptop...Overheating is caused by CPU..so if you can opening the CPU, clean the CPU for both cooler and CPU surface, then put into it a cpu thermal grease. This way will reduce CPU temperature.
Aug 08, 2011 | Computers & Internet
Cpu in my coputer overheating to 65 c ,and blue screens appear and computer restart , what the reasons
Well your cpu is overheating. The cuase may be the cpu fan. So try to replace the cpu fan.
Regards, polysandy
May 19, 2010 | Intel Motherboard
Turns off after 1-2 mins like it got unpluged dell dimension 2350plus the clip to the heat exchange on top of the cpu broke
it's probably the cpu overheating because of the broken clip. You'll need to buy a new heatsink for the cpu (get some thermal paste at the same time). Take the old one off, clean the compound off the top of the cpu. Put a pea-size blob of thermal paste on the cpu and attach the new heatsink.
Sep 23, 2009 | Dell Dimension 2350 PC Desktop
My cpu shitches on and off while i am working
Download SpeedFan software and check if the CPU is reaching critical temperature.
If the CPU is overheating replace heathsink fan.
If CPU is not overheating try reinstalling Windows operative system to fix the problem, that usually can fix this kind of fault.
Aug 14, 2009 | Acer Computer AOA150 Notebook
Automatic shutdown without notice
its because CPU get hot. check the cpu fan or
clean that, heatsink of cpu fan must be clean and closed to cpu.
Aug 01, 2009 | Acer Aspire 5315 Notebook
Overheating although cooling fan & heatsink are ok
u r saying that the laptop is overheating. I think it is from cpu overheating right. just to make sure that it is cpu overheating, just go to the following link and download the software around 1mb which displays each and every component heating levels.
from that you can find out the exact component.
http://www.cpuid.com/software.php
if cpu is heating then just replace the thermal interface material and the problem will be gone.
if the cpu thermal interface material is too old then this type of problems arises
Apr 19, 2009 | Computers & Internet
Computers & Internet Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
