Question about Dishwashers
Meiko ecostar 530f
What is error code 301?
2 Suggested Answers
whytfang
  • 170 Answers
SOURCE: i need an instruction manual for meiko ecostar 530f dishwasher
Go here and see if your manual is there...I hope this helps...thanks for rating my effort.....The Fang
http://www.meiko.us/downloads.htm
Posted on May 13, 2009
I have a Meiko Fv40.2 with two codes coming up, 302 and 325. Can you tell me what the codes mean.
Error 302: Drain pump output low/defective/unplugged, drain hose kinked, no signal from I/O board, wash tank level sensor malfunction.
Error 325: Tank has overfilled, drain pump active to decrease level. Allow machine to drain.
These are straight out of their tech manual.
Mar 01, 2017 | Meiko Dishwashers
Meiko 530F leaks from doors bottom corners while washing, any hints, water level senson seems fine
Make sure the jets in the UPPER arm are all clear, and that there's no debris inside the top turret. On the bottom arm, IF the lower turret has (or is supposed to have) a rotating baffle, make sure it's in place - this looks like a very loose washer on the lower turret, running in a groove ~ the plastic versions get lost, the metal versions slip down and don't do their job.
Clean the drain channels along the bottom of the door and especially around the hinges, you will probably need a thin bottle brush or a steamer to get into the nooks and crannies.
Feb 20, 2015 | Meiko Dishwashers
Po 121 code
Error 121 with Meiko dishwasher means
Door not closed Check connection S1
Change microswitch
Check microswitch adjustment
Replacing a defective I/O circuit board
Apr 18, 2014 | Meiko Dishwashers
Meiko manual 530f
I have a meiko 530f.
recently suddenly switching off while washing.
furthermore, the first washing cicle doesn't seems to end e any ad
Would you have any advice on that?
Thanks
Jackl'yn
Jan 03, 2014 | Dishwashers
Error code 301-0001 on i-sensys MF 4450
Show error code 301-0001 after press (Problem with Canon i-SENSYS MF4140 All-In-One Laser Printer
Error code 301-0001 on i-sensys MF 4450cont: 8016185745-dulal
Nov 27, 2012 | Canon i-SENSYS MF4140 All-In-One Laser...
MEIKO DV 80.2 ERROR CODE 305
305 Booster content is insufficient for rinsing
See error code 301, booster tank level sensor defective/disconnected, water inlet strainer is soiled, booster tank vent is clogged, anti siphen flap.
301 Level 1 not reached when filling (number of cycles exceeded)
Booster pump output low/defective, rinse nozzles clogged, wash tank level sensor soiled, moisture in sensor tube, hose kinked or not water tight.
Mar 23, 2012 | Meiko DV 80.2 Dishwasher
What does error code 205 mean on the Meiko FV40.2
This error code means your booster heater is not getting up to the proper temperature. You can check your amp draw across your booster heating element to verify it is in fact heating and not blown. Also, check your temp sensor for resistance. At room temperature, you should read about 1000 Ohms. At 180 degrees, you will read about 1500 Ohms.
Mar 15, 2010 | Meiko FV 40.2 Dishwasher
I need an instruction manual for meiko ecostar 530f dishwasher
Mar 30, 2009 | Meiko DV 80.2 Dishwasher
Meiko FV40.2 Error codes
212
Boiler temperature too high
Contactor faulty, probe faulty, check connection on XA5
The code 312 is the same as a code 212 as stated above.
There are dozens of error codes and you should be able to get them from your local meiko dealer, hope this helps, colin
Mar 10, 2008 | Meiko FV 40.2 Dishwasher
Dishwashers Logo
Top Dishwashers Experts
