Question about Dishwashers
Meiko ecostar 530f
What is error code 301b
2 Suggested Answers
whytfang
  • 170 Answers
SOURCE: i need an instruction manual for meiko ecostar 530f dishwasher
Go here and see if your manual is there...I hope this helps...thanks for rating my effort.....The Fang
http://www.meiko.us/downloads.htm
Posted on May 13, 2009
Meiko 530F leaks from doors bottom corners while washing, any hints, water level senson seems fine
Make sure the jets in the UPPER arm are all clear, and that there's no debris inside the top turret. On the bottom arm, IF the lower turret has (or is supposed to have) a rotating baffle, make sure it's in place - this looks like a very loose washer on the lower turret, running in a groove ~ the plastic versions get lost, the metal versions slip down and don't do their job.
Clean the drain channels along the bottom of the door and especially around the hinges, you will probably need a thin bottle brush or a steamer to get into the nooks and crannies.
Feb 20, 2015 | Meiko Dishwashers
Po 121 code
Error 121 with Meiko dishwasher means
Door not closed Check connection S1
Change microswitch
Check microswitch adjustment
Replacing a defective I/O circuit board
Apr 18, 2014 | Meiko Dishwashers
Meiko manual 530f
I have a meiko 530f.
recently suddenly switching off while washing.
furthermore, the first washing cicle doesn't seems to end e any ad
Would you have any advice on that?
Thanks
Jackl'yn
Jan 03, 2014 | Dishwashers
Error 305 on meiko dv200.2 what does it mean?
Could be a faulty booster level / pressure switch. Do you hear the air gap cup filling in the back? Could be a faulty fill solenoid (aqua stop hose with solenoid at water inlet.)
Aug 31, 2013 | Meiko DV200.2 Door-Type Dish Machine
Meiko dv80.2 message: info 124 we don't know what
you have opned the hood close the hood the error will disapear
Jun 13, 2011 | Meiko DV 80.2 Dishwasher
What does error code 205 mean on the Meiko FV40.2
This error code means your booster heater is not getting up to the proper temperature. You can check your amp draw across your booster heating element to verify it is in fact heating and not blown. Also, check your temp sensor for resistance. At room temperature, you should read about 1000 Ohms. At 180 degrees, you will read about 1500 Ohms.
Mar 15, 2010 | Meiko FV 40.2 Dishwasher
I need an instruction manual for meiko ecostar 530f dishwasher
Mar 30, 2009 | Meiko DV 80.2 Dishwasher
Meiko dv80.2 error 201
Error code 201 Indicates the incorrect water level...in that the level was not achieved during filling...check the following.
Correct water level was not reached during initial filling.
Check that the water hose is correctly attached and is free of “kinks” or pinching. Also check that the water supply is turned on.
I hope this helps...thanks for rating my effort....the Fang
Jan 30, 2009 | Meiko DV 80.2 Dishwasher
Meiko FV40.2 Error codes
212
Boiler temperature too high
Contactor faulty, probe faulty, check connection on XA5
The code 312 is the same as a code 212 as stated above.
There are dozens of error codes and you should be able to get them from your local meiko dealer, hope this helps, colin
Mar 10, 2008 | Meiko FV 40.2 Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
