Question about Drills
Battery wont charge
My 9.6 v ryobi wont charge, i put in the battery and the charge light does not light up. there is a radio attached and it is working.
  • 10,865 Answers
That battery is shot and must be replaced.
Posted on May 20, 2009
I have a brand new Ryobi kit put battery in the charger the red light goes on and the green light flashers on and off is this charging or should the green light go off until battery is charged.
When the battery is charged the green will be steady on and the red will go off. Flashing green is an indication that it is charging.
hope this helps?
Jan 19, 2016 | Ryobi 18v Combo Kit P845 4-tools/...
I have a 9-3 saab and ive had new battery put in my car and something is draining battery it wont hold a charge what could it be??? I should also say that my radio amp has gone too.
A mechanic would disconnect the battery and check each circuit for a short to ground or a voltage draw with the key off.
Common problems are a light left on or a faulty relay.
Jul 15, 2012 | 2003 Saab 9-3
If the battery is draining when the car is off most of he time it is from eather a light on the you may not be able to see like a glove box light or a radio staying on
to fix this u will need a test light (borrow one or buy one there cheap if u dont have one)
disconnect the positive battery cable attach one end of test light to the positive battery post attach other end of test light to the disconnected battery cable if the light real bright start pulling fuses until the light goes out or goes real dim (the dim light is the draw from computer,radio,etc so small of draw wont hurt battery) once you pull the fuse that makes the light go dim or out check that circuit for short circuits
if when you put test light on light not on or real dim before u pull fuses you more than likely have a weak battery that wont hold a charge
Feb 11, 2011 | 1996 Jeep Grand Cherokee
Ryobi 18v lithium battery won't charge
sound to me like you have a bad battery, a lot of ryobi batterys don't last like they should i have had the same problem, but my battery was less than a year old and i took it back and they give me a new one.
Mar 15, 2010 | Ryobi 3-piece 18V Drill / Circular Saw /...
The Ryobi 18V battery will no longer charge in the charger.
If you have a battery that will still charge you can take the one that wont charge and place a small jumper wire in both sides of the battery. + and - Then put it in the charger. place the jumper wires + to + and - to - for one sec and you will see the yellow light go off and it will charge.
Jul 13, 2009 | Ryobi 15" Electric Factory Reconditioned...
Some Ryobi 18v batteries charge, others don't.
Had the same problem with some makita batteries, Was going to throw them away so decided to take apart and see what was happening. The are made up of 1.5 volt cells soldered together, found that many had .9 volts or less and others had 1.5 or more. This means that some of the cells had gone bad (probably due to lack of chemical reaction). Found that if I collected all of the 1.5 volt together could charge just fine. Problem is it is very hard to get them all soldered back together and even harder to enclose them. If a mfg. could come up with some way to change cells individually they could make a lot of money and save us a lot. So the answer to your question is buy you at least one more battery and recycle your old one.
Mar 28, 2009 | Ryobi Multi-Volt Battery Charger
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Jan 30, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Drills Logo
204 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
