Question about Vacuums
H20 mop replacement parts
Steam mop producing water and not steam from main nozzle
SOURCE: My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Posted on Feb 06, 2009
satch498
SOURCE: shark steam mop
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
Posted on Jun 30, 2009
heatman101
  • 43501 Answers
SOURCE: shark steam mop model #S3202 is no longer heating
The heating element may have died or there is an obstruction...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Posted on Sep 03, 2010
heatman101
  • 43501 Answers
SOURCE: shark steam mop has water, but there is no steam....
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 05, 2010
heatman101
  • 43501 Answers
SOURCE: I loved my Shark Steam
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
heatman101
Posted on May 19, 2011
I have the original H20 Mop. The light comes on, I feel the motor humming but no steam.
Hello, this is Ava with Think Crucial.
The are a number of reasons why your H20 mop doesn't steam. Ensure that the water tank has correct level of water. Check if the Steam Nozzle has a blockage and clean if it's necessary. Also, check for limescale deposit and removed it. You may refer to your unit's manual for procedures to remove limescale.
You can purchase a wide variety of high quality replacement microfiber mop pads for your H20 mop from ThinkCrucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=h20+mop
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 16, 2016 | H20 Vacuums
My H20 x5 steam mop keeps tripping the electric I have changed the fuse but this still keeps happening please advise?
Please stop using the mop before you have the thing catch on fire, or even your house/apartment.
What may have happened is the steam/water may have gotten in to the motor some how and is shorting it out.
Jul 11, 2016 | H20 x 5 Mop
Mop turns on but will not produce steam, how can I fix this ?
SOLVED: How to Fix a Broken Shark Steam Mop - YouTube
? 3:24
www.youtube.com/watch?v=Vz8OvV30sHMMar 20, 2013 - Uploaded by ProvenHelper I never used distilled water in my Shark Steam Mop and after a few years, my steam mop stopped producing ...
Oct 14, 2015 | Shark S3101 Euro Pro Steam Mop
My steam mop wont heat up
Don't have one I need to get it replaced
Oct 13, 2012 | Reliable H20 Steam Mop
My mop will not produce steam after troubleshooting/cleaning as recommended-why
test the nozzles, gasket if there are attached o.k 2( examine the hose blockage 3( test the pump 4( test the motor 5( test the belt 6( see the tank is full or are broken and replace, can get air in the system see the diagram and proceed with common sense. God bless you
Sep 06, 2012 | H20 x 5 Mop
Shark S3101 Steam Mop won't produce steam
You have to use distilled water in the steam mop. regular water clogs it up and causes it not to work.
Nov 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The mop just stopes making steam to the head. Could this be A heat coil problem? Also a lot of others have had This happen.
On these steam mops, you have to use distilled water, if you use tap water and do not have a house water softner or some kind of water filtration system, the water running thru the tubes of the steam mop
will develop calcium deposits, these deposits are caused by hard water and will clog up the tubes, and keep the mop from producing steam, then you will have to replace the lines. i own this brand of steam
mop and had the same problem you had, I replaced the lines and started using distilled water, and have not had any problems since and that was last year. good luck!
Aug 18, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Unit gets hot but doesn't produce steam!
heatman101
l
Aug 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
184 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
