Question about Rockstar Games Video Game Consoles & Games
Misfire code p0302 cylinder - Rockstar Games Video Game Consoles & Games
  • 102 Answers
SOURCE: Have fault code P0302 on 2001 VW Beetle. No it is
this car has what is called coil over ignition which means no plug wires or cap so if it is missing swap coil from cyl 2 and any other cyl then clear code and rerun car till light comes back on then check code if it is still cyl 2 missfire then replace that plug if code changes to the cylinder that 2's coil was on then replace that coil <that car does have a recall for coils> if car is not missing and you have that code most likely isnt an ignition problem but will have a small vaccume leak so check the small hoses for leaks. very common for fuel preasure regulater vaccume hose to brake from age
Posted on Mar 22, 2009
Selvol
  • 115 Answers
SOURCE: Misfire with error codes P0300,P0302,P01303, P0102, P0748
Have you tried new Spark Plugs? Also after removing the plugs.
Take a paper towel and roll it up so it is like a long thick pencil. Stick that down the hole the spark plus came out of. Just to clean the moisture out. Also blow some compressed air down the hole.
Make sure all the moisture is out. The put the plugs in.
When you wash you car. Be careful if you wash the engine.
Dont let water get in to the plug holes..
Posted on May 21, 2009
have you checked the wires for holes.
Posted on May 28, 2009
ZJLimited
  • 17970 Answers
SOURCE: my 2001 jeep grand cherokee laredo is having
P0300 Diagnostic Code - Random/Multiple Cylinder Misfire Detected
Basically this means that the the car's computer has detected that not all of the engine's cylinders are firing properly.
A P0300 diagnostic code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a P0300 doesn't tell you specifically which cylinder(s) is/are mis-firing, nor why.
Symptoms may include:
the engine may be harder to start
the engine may stumble / stumble, and/or hesitate
other symptoms may also be present
Causes: A code P0300 may mean that one or more of the following has happened:
Faulty spark plugs or wires
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Burned exhaust valve
Faulty catalytic converter(s)
Stuck/blocked EGR valve / passages
Faulty camshaft position sensor
Defective computer
Possible Solutions:
* If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
* If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Random misfires that jump around from one cylinder to another (read: P030x codes) also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open.
About P0301 or P0302 code, this means that the the car's computer has detected that one of the engine's cylinders is not firing properly. In this case it's cylinder #1 and #2.
Causes: A code P030x may mean that one or more of the following has happened:
Faulty spark plug or wire
Faulty coil (pack)
Running out of fuel
Poor compression
Defective computer
Possible Solutions:
Hope helps (remember to rate and commet this answer).
Posted on May 13, 2011
SOURCE: p0302 cylinder 2 misfire detected enginge revs
P0302-Cylinder 2 Misfire Detected How do I track down the problem and fix?
Posted on Sep 06, 2011
2013 BMW X5 replaced the spark plugs coils still have the p0301 p0306 codes
Trouble shooting a misfire, Code P0300, P0301 ... - YouTube
? 23:39
https://www.youtube.com/watch?v=G_grIaTgdRI
Oct 26, 2013 - Uploaded by Robert DIY
Trouble shooting a misfire, Code P0300, P0301, P0302, P0303, P0304, P0305, ... How to Diagnose Codes P0301 - P0310 - Cylinder Misfires ...
Diagnose and Repair Misfire Diagnostic Codes P0301 ...
? 9:22
https://www.youtube.com/watch?v=yK7v11ASVgI
May 6, 2014 - Uploaded by JamieJones TheCarMan
Diagnose and Repair Misfire Diagnostic Codes P0301,P0302, P0303,P0304,P0305,P0306 On A Hyundai ..... P0303 Honda cylinder 3 misfire detected code - Change spark plug - ELM327 OBDII reader with Torque - Duration: ...
? 15:59
https://www.youtube.com/watch?v=Sg7iFytxfzQ
Feb 16, 2014 - Uploaded by Robert DIY
Misfire Trouble Shooting: 30 to 60 minutes ($50 / $75 / $120) If your car is ... Diagnostic Codes P0301,P0302, P0303,P0304,P0305,P0306 On A ...
Dec 08, 2015 | BMW 2013 X5 xDrive35i
Why won't my car start?
P0300 multiple misfire
P0302 misfire cylinder 2
P0306 misfire cylinder 6
Apr 25, 2015 | Cars & Trucks
Codes P0300 P0302 P0303 P0304 P1176 P0133 P1300 P1580 P1543 B0423is running but having trouble building speed and going up hills
Codes p0300 random misfire, p0302-0304 misfire cylinder 2-4. P0133 o2 circuit slow response bank 1 sensor 1. P1176, P1300, P1580, P1543, B0423 r make specific which you didn't say this would cause the problems you are having.
Apr 07, 2015 | Cars & Trucks
I would like to know what these codes mean
P0171 System Too Lean (Bank 1)
P0174 System Too Lean (Bank 2)
P0301 Cylinder #1 Misfire Detected
P0302 Cylinder #2 Misfire Detected
P0304 Cylinder #4 Misfire Detected
P0306 Cylinder #6 Misfire Detected
Mar 12, 2014 | 1999 Ford Explorer
What are codes 302 303 misfire that come up and how do i fix it
the codes are p0302 and p0303 p0302 if a misfire in cylinder number 2 p0303 is a misfire in cylinder number 3
Mar 30, 2012 | 1997 Honda Accord
P0440 and P0302 scan code - changed plugs and wires. Changed emission purge valve. All vacuum lines appear to be OK. Fuel lines are not leaking. Good spark to cyclinder two when using spark tester. ...
Cylinder 2 Misfire Detected po302 . Evaporative Emission Control System po440 The last digit on a misfire code indicates the cylinder number. A code P0302, for example, would tell you cylinder #2 is misfiring. Chances are the misfire is due to a weak ignition coil. Did you change the pcv valve? Remember to put the o-ring on the new one or this problem will happen.
Sep 24, 2011 | 1997 Buick LeSabre
Error Code P0302 1996 Volvo 850 GLT
Diagnostic Test Code (DTC) P0302 has a generic description of "Cylinder Misfire - Cylinder Number 2".
A misfire simply means that when it came time for that cylinder to fire, it missed its chance.
There are many things that can cause a misfire. Some of the things are listed below. Diagnostics should be performed to eliminate the possible causes so you don't spend a lot of money replacing parts trying to "guess" what is causing it.
These are just SOME of the possible causes:
> Spark plugs
> Ignition cables
> Ignition coil
> Distributor cap (if equipped)
> Fuel injector
> Fuel injector circuits
> Burned engine valves
> Blown head gasket
> Cracked cylinder head
> Piston damage
> Cylinder block damage
> Broken valve springs
> Damaged camshaft
> Vacuum leaks
Sep 10, 2011 | 1996 Volvo 850
Showing code 302 running with a sputter
if your saying its a P0302, it means this Cylinder 2 Misfire Detected check here for solutions http://www.obd-codes.com/p0302
Jun 14, 2011 | 1999 Chevrolet K1500
I have a 05 VW Pessat with a 1.8L 65K miles on it. I have a random misfire and surge at idle. Code's set: P0300, P0301, P0302 and I seen P0303. This misfire comes and goes. Does not have a dead miss. I...
Try the crank pisition sensor that is vary likely to be the couse of your misfires its working but its intermintly shorting out telling the pcm that you have a misfire and setting the codes
Nov 22, 2010 | 2004 Volkswagen Passat
Video Game Consoles & Games Logo
148 people viewed this question
Top Rockstar Games Video Game Consoles & Games Experts
Edward Talavera
Edward Talavera
James Wishart
Sreehari Nair
Sreehari Nair
Level 1 Expert
Are you a Rockstar Games Video Game Console and Game Expert? Answer questions, earn points and help others
