Question about Sony KV-35S40 TV
Picture goes off but i have sound - Sony KV-35S40 TV
  • 2 more comments
  • Anonymous Dec 11, 2007
    my telivision works but the picture wont show
  • Candi caine Jan 06, 2008
    The picture went out but I still have sound!! How can I fix this with out having to spend lots of money to have someone look at it?
  • Anonymous Jan 29, 2008
    i have no picture
  • mfox001 Jul 20, 2008
    Turn on TV and seems OK, then no picture but have sound. There is a blinking light that blinks seven times during no picture. Called sony 800 number and received run around.
    Thank you
I got KV 32ts 46 Sony
Turn on TV and seems OK, then no picture but have sound. I turn it on and off some time pictures come back but goes out again. Pleas help
Posted on Nov 17, 2008
  • Sony Master
  • 5,138 Answers
Usally this means you are losing your filamint voltage which can be caused by leaky or bad capacitors, also you could have a resistor bad that feeds over to high voltage,no picture means you have lost of high voltage to or from flyback transformer.
Posted on Dec 23, 2007
  • ladywinn
    ladywinn Jan 17, 2008
    look next to or behind hori output transistor thier is a 1200pf 2k volt capacitor that goes bad,i have replaced many of these and it has fixed problem.
  • 93 Answers
Resolder the flyback side,most of problem is cause by loose contact only
Posted on Oct 19, 2007
SOURCE:
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
I have a sony kdf 50e-2000 the green light goes on then it goes to thr red blinking lamp light. I have no sound or picture. If I replace the lamp light will I get sound and a picture again?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
For a new Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony KDF-50E2000 50" HDTV
Picture goes blank and then comes back, it does it randomly but quite often. Other times it doesn't happen at all. There is no interruption in sound. Any idea what the problem is?
Is the sound affected too? Do you hear a clicking noise when the picture goes off? Is there a dull glow on the screen when the picture goes off? Sounds like a power supply/ inverter related fault but just to be sure.
Aug 18, 2010 | LG 42LC2D 42 in. LCD HDTV
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
47in Phillips-tv picture goes black still has
Could be the signal board has a bad cap, in this case it sounds like you are getting intermitten power to the inverters....when the tv goes down and of course you have audio....Shine a flashlight on to screen and see if you have a picture...look carefully. If this is the case..you have the above problem!
Nov 23, 2009 | Televison & Video
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
No picture yes sound
I was told that this problem could be the power board.
Jun 17, 2008 | Televison & Video
Same problem: picture goes out
Sounds like you need to replace the lamp. The owners manual should show you how to replace the lamp. You can order the lamp through Sony on their website. Good Luck
Jan 24, 2008 | Sony KDF-E55A20 55 in. LCD Television
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KV-35S40 TV Logo
472 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
