Question about Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop
It keeps rebooting
My computer goes to the start windows normal screen then when you select it. it reboots i have also tried to start it in safe mode it won't and it won't boot from CD so that i can reformat it please help I'm getting frustrated
  • 4 Answers
Persistent reboots and/or random reboots often indicate a failing power supply.You might also check the motherboard battery,which keeps the power for the BIOS,so your computer knows HOW to start.
Posted on Oct 19, 2007
  • 883 Answers
Boot from floppy disc?
How do I turn off the safe mode
There are many reason for a system goes to safe mode. Normally, it is the hardware conflicting with the software and drivers. It goes to Safe Mode to load minimal drivers and small resident programs called TSRs. Here is the solution to solve the issue
Follow the steps:
Immediately begin tapping the "F8" key when the reboot sequence begins (make sure your "F Lock" key is activated.) Once the black "safe mode" screen appears, then first try selecting the option "Start Windows Normally" using your mouse or keyboard up and down keys. Allow Windows to boot, log into your profile and wait for the program to fully configure. Once that is completed, go to the "Start" button and select "reboot." If all is well, the "safe mode" will not reappear.
If that fails, then repeat the reboot sequence -- tapping the "F8" key repeatedly -- and when "safe mode" reappears, choose the "Last Known Good Configuration" selection and allow it to go through the same sequence as in the above paragraph.
If the above does not work and your system continues to first boot into "safe mode" it is possible that a setting in the boot configuration file is checked.
For that go to start -> RUN and Type in "msconfig" in the provided box and hit "enter." The "System Configuration Utility" will appear. Using your mouse or right arrow key, select the "BOOT.INI" tab. Look for the "boot options" section and the "SAFEBOOT" selection box. If it is checked, uncheck it, select the "Apply" button and then "OK."
Go to the "Start" button and select "reboot" and your machine should now boot directly into Windows.
Apr 28, 2018 | The Computers & Internet
I start my computer up put my pass word in and then the sreen goes blank with just the mouse arrow showing could you help
unplug everything... even the USB stuff what about 1min. then just put the power cord only back in and log back in.
Feb 07, 2015 | Dell Computers & Internet
DELL STUDIO 1737, WITH WIN 7, WILL REBOOT AT SHUTDOWN.\r\nIT SHUTSDOWN FOR ABOUT 3 SECONDS, THEN REBOOTS TO A BLACK SCREEN WITH: "WINDOWS DID NOT SHUT DOWN PROPERLY, SELECT ONE OF THE FOLLOWING:" Start...
operating system issue try to repair os or make a clean new os installation (make backup before you go for clean instillation...
best try to repair and restore....
thanks
Aug 18, 2017 | Dell Studio 1737 Laptop
When I turn on my computer it goes to either choosing safe mode,
There are many reason for a system goes to safe mode directly.here is the solution to solve the issue
Follow the steps:
Mar 17, 2010 | ASUS Eee 4G Notebook
Spontaneous Rebooting
Hi ,
Which anti-virus have you tried to install and reinstall as it can happen if its not properly installed.Please check if its manually uninstalled. Try rebooting the system in safe mode . Go to Run type msconfig and select Normal Startup save and reboot.
Jan 28, 2010 | Microsoft Windows XP Professional for PC
When trying to boot up
Hello
So in that case you need to reinstall the Windows so that it will fix the problem. Some instances of that problem corrupted Operating System it needs a new copy.
Regards
PCmania
Sep 25, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computer will not boot up. I have tried to boot up in safe mode, normal, safe mode with prompt command...nothing works, just goes back to the normal start up screen and keeps doing the normal start up over...
It looks like you're encountering an endless reboot? Here's what to do to find the actual error message.
  1. Turn on the computer, and press F8 after the POST screen but before Windows attempts to start to access the advanced startup options.
  2. Select "Disable Automatic Restart On System Failure" and press Enter.
You should now get a blue screen with an error message and error codes. Please write these codes down and report back.
Mar 24, 2009 | HP Compaq Presario SR1830NX PC Desktop
Laptop stuck on screen "Windows is resuming"
First determine if windows is really hung.
Restart the laptop and keep pressing the F8 function key. You will get a menu. Try the safe mode option by selecting it with arrow keys and pressing enter. Click on Yes when it asks the question.
If Windows runs okay in safe mode, reboot and try starting normally without pressing any keys). If again it won't start, then go back to safe mode and when asked the Yes/No question, reply with a No and it will ask you to do a system restore. Just select a recent restore point say one or 2 days ago or the most recent and select restore. It will take some time and reboot the system. Now everything should be hopefully okay.
HTH,
Deboo
Jan 03, 2009 | Microsoft Windows Vista Home Premium with...
I have a Compaq laptop (a presario V2000) and the computer whenever started seems to at first be normal but then goes to the windows is starting up screen but it never starts up it stays frozen on this...
reboot the computer while tapping the F8 key... in that menu choose safe mode... after it has successfully rebooted into safe mode... reboot normally... if that does not work... repeat the above steps but boot to last known good configuration
Dec 19, 2008 | Computers & Internet
Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop Logo
215 people viewed this question
Clive
Clive
Alun Cox
