Question about Whirlpool LHW0050PQ Front Load Washer
Fault F07 Whirlpool GB AWo/D 5506 What does this fault mean
  • ocaircontipp May 20, 2009
    Thanks .. great help . its under warranty so better get them to fix it . thought if was something simple i could get it going again
    Regards
    J
  • 10,865 Answers
F07 Motor control unit error The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the MCU
• Check the Drive Motor
• Check the Wire Harness
Replace failed component.
Posted on May 20, 2009
  • Joe Hogan May 20, 2009
    Great. I am so happy to hear that it is under warranty. take care.
If it is showing a f07 what do that means
That is a motor control error. The component that runs the motor has a fault. IT might be wires or the controller.
Jul 31, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Tip
Yes I found a child's hair clip in my case. Beforehand I had the 'Clean Pump'...
This advice is for Kenmore Elite, Whirlpool Duet and Maytag Epic model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on May 30, 2010 | Washing Machines
Free whirlpool repair manual
Hello, Without a model number, I can be of limited help. But the F07 fault on a whirlpool dishwasher is indicating a problem with the water intake flow meter. Check the connections at the meter, if good replace the flow meter.
Unplug the appliance.
Take it out of it's installed location
Remove the left side panel .
In the large plastic tank on the left side of the machine is the flow meter. It will have a 2 wire plug on it.
Pull the plug off and push it on again a couple times.
Make sure the connection is dry and tight.
Try the dishwasher.
If you receive the F07 fault again, replace the flow meter.
Apr 21, 2014 | Dishwashers
Whirlpool AWO/D 8708
F07 is a fault with the motor control, probably the triac has failed.
Jun 16, 2017 | Washing Machines
Can not find model no.of the oven. Fault F07 on
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 09, 2011 | Whirlpool RBS307PVS Stainless Steel...
Hi, on my WAE8987 Washing machine, the fault code 'F07' keeps coming up, can anyone help please? thanks
Bauknecht are built by Whirlpool.
F7 on Whirlpool means flow meter failure.
Check water inlet, check the pressure switch, and check the sump filter at the bottom of the dishwasher.
To reset try turning on the power and holding the start button and the + and - buttons at the same time.
Dec 01, 2009 | Bauknecht Dishwashers
APC BR1500LCD Fault F01
This is a printout of the fault codes
System Fault indicator is on and all other
front panel indicators are flashing.
Internal UPS fault. One of nine Internal UPS Fault Messages is displayed:
F01 - On-Battery Overload F06 - Relay Welding
F02 - On-Battery Output Short F07 - Temperature
F03 - On-Battery XCap Overload F08 - Fan Fault
F04 - Clamp Short F09 - Internal Fault
F05 - Charger Fault
Nov 23, 2009 | APC BR1500LCD UPS System
Whirlpool aws 3551 fault FO7
Hi
Fault F07 is a Motor Control Unit Error. It means that the Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes. To resolve this issue you need to:
  • Check the MCU
  • Please revert for further assistance.
    Thanks
    Rylee
    Jul 25, 2009 | Whirlpool Washing Machines
    Whirlpool LHW0050PQ Front Load Washer Logo
    510 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
