Question about Precor C932i Treadmill
Remove TV screen
I need to remove a TV screen from my Precor Treadmill C954i/C956i. Please can you help me?
5 Suggested Answers
  • 218 Answers
SOURCE: The quick start button does not do anything,
You would need to replace the keypad overlay on the console.
Posted on Aug 13, 2010
  • 1833 Answers
SOURCE: I have a Precor c956i
Removethe red "STOP" cover. The cover may pushes against a switch. If theswitch moves too far down and rests against the cover, it will be stuck in alock position causing the error message. To remove the red STOP cover, removethe few screws behind the console. When the front cover is off, turn it overand unscrew the two screws that hold the red stop cover. Then push the coverout through the FRONT. Do not attempt to lift it out by the end with the screwholes. It will not pull out that way. Test the machine before screwing thepanels back again. The message should no longer show STOP KEY. Test the visiblewhite small switch that you uncovered by removing the red flap. The messageshould stop when you press the switch. If theproblem still exists then open the console and check under the magnet holderfrom inside you may see rust ire broken cable there, if you find thisthen you may have to replace it. Hopethis will help you.AV
Posted on Jun 11, 2011
ercupa190
  • 12223 Answers
SOURCE: I currently replaced the walking
Dear Sir:
I can read you trouble, and follow the next steps:
ALIGNING AND ADJUSTING THE RUNNING BELT
The correct alignment of the running belt is critical to the smooth operation of the treadmill. The belt is properly aligned at the factory. However, during shipping and handling or by use on an uneven surface, the belt may move off center and require a few simple adjustments. Before aligning the running belt, check its operation by following the procedure in Checking the Alignment of the Running Belt. If you determine that the belt needs alignment, follow the instructions here. CAUTION: Special care must be taken when aligning the running belt. Turn OFF the treadmill while adjusting or working near the rear roller. Remove any loose clothing and tie back your hair. Be very careful to keep your finger or any other object clear of the belt and rollers, especially in front of the roller and behind the deck. The treadmill will not stop immediately if an object becomes caught in the belt or rollers. Realigning the belt takes a few simple adjustments. If you are unsure about this procedure, call Precor Customer Support (see Obtaining Service.) Take the following steps to align the running belt on the treadmill. To ensure your safety, make all adjustments while the treadmill is OFF. 1. Make sure the treadmill is OFF and the running belt has completely stopped. 2. Locate the right belt adjustment bolt in the rear end cap of the treadmill. (To determine left and right, stand at the rear of the treadmill and face the display.) See Diagram 24. The direction you turn the bolt depends on how the belt is tracking. Make all belt adjustments on the right rear corner bolt using the hex key provided. • If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise, which moves the running belt to the left. • If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise; this moves the belt to the right. Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening the bolt can damage the treadmill. 3. Turn the unit ON. 4. Stand beside the treadmill and press QUICKSTART. 5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??². The running belt starts automatically after the 3-second countdown appears on the display. 6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph). 7. Walk around to the rear of the unit and observe the running belt for a few minutes. The belt should run centered along the running bed. If the belt drifts off center, you will need to make adjustments. CAUTION: If you hear any chafing or the running belt appears to be getting damaged, stop the running belt immediately by pressing the red STOP button. Contact Precor Customer Support. 8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt is properly aligned. 9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill. Tighten any loose fasteners or other components on the equipment. If you hear unusual noises or you feel that the treadmill is in need of repair or service, contact Precor Customer Support. Refer to Obtaining Service.
Finally, check if the power cord is loose, connect it again. a) See if the breaker of Home is tripped? b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little. Try again.
Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
E. CUADRA Managua, Nicaragua. C.A.
Posted on Sep 26, 2011
ercupa190
  • 12223 Answers
SOURCE: precor c954i can speed up but cant reduce the speed
Dear Sir:
Please adjust the speed sensor see the diagram attached.
After RUN the software calibration for easy diagnostic and troubleshooting
See my personal TIPS FOR Help.
sincerely. God bless you
ernesto cuadra
managua, nicaragua.
Posted on Mar 31, 2012
My treadmill precor 954i showing stuck key. So what solution for this problem???
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This is normally caused by a stuck key on your keypad. To resolve this issue, you must replace the keypad.
The following link may help, but you will need your serial number to find the correct item.
Repair Parts for Precor C954i Treadmills 120VAC 240VAC SPORTSMITH net
Nov 13, 2015 | Precor Exercise & Fitness
Why does my precor C954i keep shutting off
It must have been crossing its excess weight limit..
Jun 26, 2014 | Precor C954i Commercial Treadmill
My PRECOR TRM 800 wiht the P80 console will not work with Quick Start.
If rebooting the treadmill does not fix that, it may have a problem with the Autostop feature. The MCB may need to be replaced to fix that problem.
May 27, 2014 | Precor C956i Treadmills with HR /...
Precor c954i error 16
Precor Error 16, AC Input Voltage Too Low Probable Cause 1. AC input voltage is incorrect.
2. Treadmill operating on undersized AC wiring and/or is drawing high current.
Corrective Action
  1. Verify AC feed into the building's circuit breaker is correct and connected to the proper transformer tap.
  2. The AC wiring must be sized to handle 20 amps of current over the loop length of the AC wiring. Voltage drop across the AC input wiring is a result of the length of the wire run multiplied by the amount of current being demanded by the treadmill. The longer the run and the higher the current the large the wire must be.Verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error 16
Sep 08, 2012 | Precor C954i Commercial Treadmill
My precor c954i displays message STOP KEY and will not run? How come?
1) adjust the reed swithc, clean , and tigh the wire connectors very well
2) run the software calibration for diagnostic and troubleshooting.
God bless you
Jun 19, 2012 | Precor C954i Commercial Treadmill
Precor c954i can speed up but cant reduce the speed
Dear Sir:
ernesto cuadra
managua, nicaragua.
Mar 30, 2012 | Precor C954i Commercial Treadmill
What does error 29 mean on a precor C954i?
Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Bad lower PCA.
3. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  3. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 29
Apr 06, 2011 | Precor C954i Commercial Treadmill
Precor C932i Treadmill Logo
50 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
