Question about Sony VAIO VGC-RB53 PC Desktop
Rplaced power unit now the monitor will not come up with anything on it. Orange light blinking on front of cpu.
Sony rcg rb 53 replaced power supply unit because it would not turn on, now it turns cpu on and nothing comes up on screen. There is a orange light on front flashing when cpu powers on.
  • 53 Answers
Make sure your monitor is connected to the proper video connection- that is if you have a video card in your machine and a video connection on your motherboard. If you connected to the motherboard and you have a video card -your screen will show nothing even though you are powered up. Dont know your situation, but just checking. Ive seen others do this.
Char S.
Posted on May 20, 2009
2000 sony kp53s75 tv wont turn on - was working great - no blinking light
This is a failure of the main power supply unit which is the Switch mode power supply- SMPS. You need to remove back panel and check the power supply for possible short in the chopper driver.
please check this link:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Oct 02, 2011 | Sony KP-53S75 53" Rear Projection...
When you press power button, computer does not boot up. only orange light blinking on and off.
Possible bad power supply. Unplug and let sit for 2 minutes. If you push the button again, and nothing happens; then replace the power supply.
Jan 06, 2011 | Dell OptiPlex GX620 PC Desktop
My computer is blinking orange light
In addition to the power supply, motherboard issues can cause the blinking power light and no boot problems. The Optiplex 270, 520, 620, 745 and 755 units are all known to have issues with capacitors on the motherboard. Here is a link to an article about this issue and what to do about it:
http://www.ccl-la.com/blog/index.php/dell-optiplex-745-repair/
I hope this helps, if sol please rate my solution.
BuddyMc
Aug 10, 2010 | Dell OptiPlex 360 Desktop Computer
Monitor looks as if there is no CPU
If the power supply is coming to CPU before activation of CPU then it must be receiving current from UPS. Don't try unplugging, You may get shock. Thank you, Sir.
Sep 17, 2009 | Computers & Internet
Sony VAIO VGC-RB42G - No Power; Blinking green light on power
Try a different known working power supply on that computer, the green light on the power supply should be constant and not blinking. The green light on the motherboard shouldn't be blinking either but if its not getting the right voltage from the motherboard then it will blink as well.
Get a different power supply and see what happens. At that point the power supply green light should be constant, if its not then your motherboard is faulty at that point, if yout the green light is blinking on your motherboard, if both are constant then reseat the memory and CPU and only have the power supply hooked up to the motherboard and not to anything else.
If you still can't get video then at that point you know the motherboard is definitely bad.
Aug 30, 2009 | Sony VAIO VGC-RB42G PC Desktop
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
Monitor is busted!
If your pc works on another monitor. I would recommend you buy a new LCD monitor or a used CRT.
The best solution if your computer works is to buy a LCD screen, I've thrown out my 17" crt screens they aren't worth anything these days. You can get a used crt from ebay
Over here where I live I bought a used crt for 25usd thats was over a year ago.
Theres really no point in trying to repair the screen if its broken, buy a working one or a brand new lcd.
Good luck.
May 21, 2008 | Gateway FPD2275W LCD Monitor
AcerPower F1 PC Desktop Problem
It could be a bad power supply. As far as I remember, this unit has a standard ATX 230 watt power supply. It should not be too hard to replace it. Its fairly straight-forward. Its a matter of removing the panel to access the connectors inside (make note of which comes from where) and unscrewing the power supply on the back of the unit. Reverse all actions to install new power supply. If you need more detailed help, reply to this post.
Apr 25, 2008 | AcerPower F1 PC Desktop
Monitor
The power supply in this monitor has probably failed, but since HP doesn't stock spare parts for their monitors you will probably need to replace the whole monitor. HP only does full unit replacements on their LCD monitor range.
HP also doesn't provide any electronic schematics so getting it repaired will be difficult.
Feb 11, 2008 | Compaq FS7600 17" Flat Glass Monitor
There is a blinking light in front of my tv blinks 8times turns off for 4seconds and starts again
Check C514 next to flyback xformer.If shorted,burnt,replace
with part # 1-161-754-00 102K / 3KV capacitor.May also have open
2 amp pico fuse in power supply......T
Oct 25, 2007 | Sony KP-53S70 53" Rear Projection...
Sony VAIO VGC-RB53 PC Desktop Logo
188 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
