Question about Panasonic PT-43LC14 Television
Need help installing a lamp
How do i install a new panasonic tv lamp?
  • 92 Answers
THERES JUS A LITTLE DOOR ON THE SIDE OR BACK OF TV.ONCE YOU FIND IT ITS PRETTY SELF EXPLANATORY FROM THERE.UNPLUG IT FIRST
Posted on May 20, 2009
How do I replace the lamp and housing unit on my panasonic PT-52LCX66
You need a TY-LA1001 lamp assembly. Our Panasonic TV Lamp and Bulb Installation Guide shows how to change the lamp and has links to Panasonic Users Manuals.
easyab@hotmail.com
Feb 11, 2011 | Panasonic PT-52LCX66 Projection Television
Ineed to reset the lamp timer on my panasonic pt-56dlx75-k tv I installed a new lamp
terryc43,
This should solve your problem.
1. Turn on the television.
2. Press the down button on the TV Display (not the remote)
3. While pressing the volume button, press the "split" or "PIP" button on the remote.
This should reset your lamp timer.
Thanks for using FixYa and for the great rating!!
hardrocko
Oct 28, 2010 | Panasonic PT-56DLX75 56" HDTV
Have installed new lamp TY-LA 1ooo How is the new age timer set???
Press and hold Volume down button on tv front and Split/Play button on remote for 6 seconds to reset lamp timer.
TV will show you lamp timer reset confirmation display.
Sep 28, 2010 | Panasonic PT-43LC14 43" Rear Projection...
I have installed a new lamp in my 52 inch panasonic hdtv and after just a minute the tv cuts off not sure why?
Hi
If the TV is working correctly during that minute then the shutdown circuit is sensing a component failure or mismatch. Did you plug the lamp, inverter, power supply back in correctly? What was the original symptom? Did the TV work OK for a minute and then after a minute go dark? If this were the case then the lamp may not have needed changing but rather a capacitor and/or IC overheating. Good luck
Apr 14, 2010 | Panasonic PT-53WX53 53" Rear Projection...
The green light blink for a while and then shuts off and the lamp light blinks once red???
The green blinking lamp means that the TV is getting ready to start the lamp, and then one red LAMP blink means the lamp will not start. You may need a new lamp (Part TYLA1001.)
If a tech confirms this, and you can source the part, you can find TYLA1001 installation instructions here to save a few dollars, and PT-52LCX66 lamp timer reset steps here.
I hope that helps.
Mar 20, 2010 | Panasonic PT-52LCX66 Projection Television
Panasonic projection tv model # pt56lcz7 no picture, bulb out?
This unit does not have the usual lamp assembly that most do. On this unit the whole light engine has to be removed to replace the lamp assembly. Part number is LFS4000PA1 and cost is $1,351.95 @ www.partstore.com.
Sep 01, 2009 | Panasonic PT-50LCZ70 50" HDTV
Tv will not click for pic to show, bulb good, just blicks green
This TV has a Service Bulletin on it that indicates you should install a Ballast Kit.
Also replace the Lamp with a Panasonic Lamp / No generic.If you just replace the Lamp only, it will burn out fast without the new Ballast Kit installed first. Call a good TV tech and have him check for this problem first.
Jul 31, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I was wondering if you could tell me how to reset the timer after I have installed a new lamp. Can you help me? tv is a panasonic pt-56dlx25 Thanks, dave
Plug the power cord back into the properly grounded wall outlet. Then press the POWER button on the projection display or the remote control to turn the power on.
2. While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneosly for more than 5 seconds.
3. Whe the lamp time reset procedure is complete, the screen will display "LAMP TIME WAS RESET TO 0." When the lamp time is reset, the LAMP indicator will go out
Dec 30, 2008 | Panasonic PT-56DLX25 56" HDTV
Replace Panasonic PT-60DL54J Lamp (TY-LA2004)
Hi Mac
Yes you can just take out the old lamp and install the new one in your existing lamp bracket. Simply unscrew , replace and screw back in.
Apr 12, 2008 | Panasonic (ET-LA995) Projector Lamp for...
Panasonic DLP Model PT-52DL52
Remove the speaker grill on the front of the tv by pulling it outward evenly, so not to break it. While looking at the front of the tv, there will be a compartment on the right side. You unscrew 1 screw and take the cover off. Then unscrew the 2 screws holding the old lamp on the tv. After you've unscrewed the previous 3 screws you should be able to pull out the old lamp. You can now install the new lamp and complete each step in reverse order.
Sep 03, 2007 | Televison & Video
Panasonic PT-43LC14 Television Logo
125 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
