F1 t2al 250v - Televison & Video
2 Suggested Answers
SOURCE: I got the ch-DVD 300 no power anymore, I opened
This is not a good solution but it is one I have used for extreme situations.
Take a single strand from an old cheap lamp cord and solder it across the ends of the fuse. This will create a new fuse of approx. 1 amp. I made a safe cross country flight in a private plane by making a temporary fuse when a new one wasn't available.
Posted on Mar 29, 2009
IZE FUSES GO INTO A BALLY STRIKES AND SPARES PINBALL MACHINE
There are several fuses. All are 3AG size. On the Rectifier board you need:
F1=10 Amp 32V
F2=3/4 AMP, 250V SLO-BLOW
F3=4 Amp, 32V
F4=5 Amp, 32V
F5=20 Amp, 32V
F6=3 Amp, 32V SLO-BLOW
On the solenoid driver board you need:
F1=3/16 Amp
Nov 01, 2014 | Video Game Consoles & Games
Diagram where fuse is in the polaroid flm-3701
There is a fuse on the power supply board. It is labelled F1. It is a small cylinder near the AC connector. The F1 fuse is 5A 250V. How ever, capacitors are more likely to fail on this television.
The Polaroid FLM3701 has a problem with capacitors failing on the power supply board. If enough caps go bad, you will get no power. Not even a power light. Any capacitor that is swollen is bad.
May 12, 2014 | Polaroid FLM-3701 Television
Fuses or not
How ever, capacitors are more likely to fail on this television. The Polaroid FLM3701 has a problem with capacitors failing on the power supply board. If enough caps go bad, you will get no power. Not even a power light. Look for swelling in the tall capacitors E8 thru E17 on the left side of the board. Also E6, E7 and E22 can go bad, but they do not swell.
Mar 02, 2014 | Polaroid FLM-3701 Television
F 1,6 A L250vol
F1 Fuse should be F1.6A 250V
Jan 16, 2014 | Fender Hot Rod Deluxe Guitar Combo...
I am not sure what fuse to put in it, when I got it it had a 500 MA Ceramic 5x 20 250v Fuse blown; but when I replace it with the same it automatically pops. The board of the power supply has written on it...
On the body of the fuse or on the circuit board there will be a suffix T or F next to the value.
T stands for Time delay or slowblow. If its marked F it means fast acting fuse.
Now after replacing the correct fuse if it still pops you have a short circuit and it is drawing high current, so the popping. Get professional help or you will do further damage.
Apr 08, 2011 | Televison & Video
I have a JVC DR-MX1SEK dvd combi recorder. It was working well when I was searching for another problem when I removed the plug from the mains socket and a blue flash came out of the recorder. I removed...
Not sure if you have resolved this but that fuse is widely available. It is a 20mm x 5mm 2 amp slow blow glass fuse. It is perfectly possible that your replacement was correct but that a separate fault in the machine is causing the fuse to blow. Remember, fuses are designed to protect things (either the machine or you) and to blow if a fault causes more current than is safe.
Jan 05, 2011 | JVC Televison & Video
I got the ch-DVD 300 no power anymore, I opened and I saw the fuse blown out,where can I get a new one? it says T2AL-250V and measures 3/4 of inch.
Feb 22, 2009 | Cyberhome CH-DVD 300 DVD Player
No power to my dell 2300mp
The fuse is a short round maroon colored part to the left of the power plug looking at the power supply module from the direction that you would connect the cord to. it is labeled F1 and it is a 4a 250v. This is not the problem with my power supply though. I suspect one of the components under the heatsink is bad.
as you all know don't bother calling dell.
Nov 02, 2007 | Dell 2300MP Multimedia Projector
No Power... need a new fuse.
While wiping off the dvd vhs player it went out. Said it did not recognize the tv anymore. My son put it on his tv and got a half screenof the movie. just took out the fuse t2al 250v. what is my problem?
Sep 11, 2007 | Cyberhome CH-DVD 300 DVD Player
No Power at all. Fuse T2AL is blown up
Thanks to Bogbrush (what a name!) above for the hint to check R5107 when the STRG6653 explodes, indeed it was open circuit. I replaced that with a non-SM component since that's what I had to hand, replaced the fuse (2AT), replaced the STRG6653 and replaced the mains rectifier since this looked to have suffered even though cold checks implied it was OK. Then rewarded with a fully working DR-MH200. I had already gone through the power supply replacing any capacitors which had gone high E.S.R, several had. The 27uF 35V capacitor in the primary circuit of most JVC DVD recorders is particularly prone to failure.
Mar 04, 2007 | JVC DRMH20 DVD Recorder
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Electro Med Services...
