Question about Dryers
THE DRYER TAKES TWO TO THREE HOURS TO DRY ONE LOAD
THE DRYER TAKES ABOUT 2 TO 3 HOURS TO DRY 1 LOAD
I had the same problem. It was the vent from the dryer to the outside of the house. An easy way to tell if this is a problem is to disconnect the vent from the dryer and dry a load of clothes. If it drys in normal time, nothing is wrong with the dryer; you have to get your vent cleaned. I tell you this because we took the whole dryer apart and tested all the other possible problems before we tried this. I wish we had tried this first.
Posted on May 28, 2009
  • 10,865 Answers
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Posted on May 20, 2009
3 Suggested Answers
aasc
  • 1606 Answers
SOURCE: My Dryer gets hot but it takes 2 hours to dry.
Go into atic and see what the vent is made of . Home depot sells 4 inch connectors whether hose or aluminum maybe 1 foot long . They may even sell a 4" brush connected to about a 10 foot cable ( a lot of parts houses do ) . Cut the tubing or hose and feed the cable down to someone who can pull the brush down . The top portion you will have to use injinuity to clean .
Posted on Jul 19, 2009
SOURCE: the dryer takes about 3 hours to dry whereas it
make sure the vent hose and outside door flapper is clear. Try drying one load with the hose off to see if its better.
Posted on Sep 08, 2009
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
My new gas dryer takes an extremely long time to dry clothes. It can take up to three hours to dry one load.
check your vent on the inside and outside of your home,, also check and make sure the vent hose is not kinked up,( sometimes when you push the dryer back it will kink it)
Jan 20, 2011 | Kenmore 8753 Dryer
My dvlr223egww takes over 2 hours to dry a load,
The most common problem is your exhaust line is blocked. Turn on the dryer and go outside to feel how much air is coming out the vent. Most likely it is blocked. If so you'll need to disconnect the exhaust duct and vacuum it out.
Oct 06, 2009 | General Electric DVLR223EGWW Dryer
The dryer takes about 3 hours to dry whereas it
Sep 08, 2009 | Dryers
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Takes 3 hours to dry a small load, dryer is 3 1/2 yrs old
You need to clean vent hose and vent line in wall of house.
May 08, 2009 | Dryers
Dryer takes hours to dry one load of clothes
I WOULD SAY YOUR DRYER NEEDS CLEANING OUT OR YOUR WALL VENT IS CLOGGED AND NEEDS CLEANING OUT-MIKE
Mar 04, 2009 | GE Dryers
It takes hours to dry small load
dud thermal sensor, the temperature is shuttimg off too low
locate, replace the thermal sensor just 'downwind' of the flame
Mar 26, 2008 | Amana NDG7800AW Gas Dryer
It takes 3 hours to dry one load
vent restiction look over the back of the drier and see if the vent is mashed folded etc then turn drier on go out side to where the hood is see how much air is comming out if very little find out whats blocking it
Dec 31, 2007 | Amana NDG7800AW Gas Dryer
Dryers Logo
279 people viewed this question
Top Dryers Experts
