Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water leaks down back of frig and pools under veg crisper
We had this problem with our previous frigerator, Can't believe this is happening again, guess we will have to get a different make. Hope you can help us.
  • 1,869 Answers
There is a drain hose that drains the frost from the freezer down to a drain in the botton of your refrigerator. then: to the evaporator tray under your refrigerator If the tube or, drain get clogged the water has no where to go and, pools in the refrigerator To fix this clean the hose with a coathanger or, stiff wire If you do not know where the hose is see the parts diagram for your refrigerator at: searspartsdirect.com
Posted on May 20, 2009
Water in veg crisper freezing
You have a white cover in the back of your fridge it says twin cool on it. Behind that cover is a drain for your defrost cover that is probably frozen and water is leaking through that cover. Wrap a piece of copper wire around the heater and fish it down the drain and it
will fix the problem
May 09, 2014 | Samsung RF265AA Bottom Freezer French Door...
I have a model RF26VABPN french door, bottom freezer unit. It has a leak of cold water pooling under the crisper trays. I can't find where the leak is coming from. I clean the water up, and within days,...
Defrost drain plugged in fresh food section. Samsung will repair it under warranty. Might pay for it if you complain nicely, if it is out of warranty.
Mar 31, 2011 | Samsung Refrigerators
U-line UC02175 water inside pooling under veg drawer, icemaker supply turned off, no water in catch pan inside back
Well sounds like your ice maker evaporator drain hole is frozen, every time the unit goes into defrost cycle, water backs up and leaks down to the drawer. You can try turn off the refer for 48hrs with the doors open, most case it will reset by it self. If it is happening again in few weeks, then you evaporator drain pan heater is not working. Also make sure the doors are shut all the time.
Feb 03, 2010 | U-Line CO2075F-B Echelon Refrigerator Ice...
Why is water pooling under the crisper drawers? someone mentioned a humidity problem but there aren't any controls so what do I do? whirlpool ET18GMXHW0
Check the water reservoir behind the crispers for a leak. It could be a clogged defrost drain also. If you keep a jug of drinking water in the frig check closely for a pinhole. These are my first places to look.
Eric
Feb 01, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is forming on the floor. Appears the water is pooling under the crisper drawer, then seeps through the seal. GE TBX 18CI. Any ideas?
You should not have any water at all forming inside the frig compartment unless you have a water dispenser on the frig. The water resevoir is located in the frig compartment at the bottom behind crisper. There may be a small leak or loose water connection on it. Hope this helps.
Jul 24, 2009 | Refrigerators
At the top of the frig where the cold air blows into a small "vent" is it suppose to still have styrofoam the inside of the small "vent"? PC Water is leaking into frig and into veg bends.
most likely the drain is clogged..if it is, the water flows to the path of least resistance, hence, into the air vents and down under the crisper..remove rear freezer panel. the drain pan is located under evaporator. Defrost the drain pan if there is ice in it. there will be a small drain hole. this is where you need to see it gets open via hot water and all will be ok..make sure you hear or see it flowing into drain pan...Bruce Denton, master tech
Jun 19, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water leaking into the bottom of frig. going under veggy crispers
Look for the drain trough on the bottom of the freezer and pour a mixture of baking soda and warm water down.
May 07, 2009 | Refrigerators
Kenmore 106.78202890 Ref. Icemaker seems to work fine. No water leaks when it fills but I have water in the refrigerator section that seems to be draining from the freezer. Any ideas?
Hi there, I believe you may have a defrost drain problem. See the water has to drain somewhere else when the drain is stopped up. So instead of into the catch basin on the bottom of the frig it cascades down the backside of the frig and ends up under the crispers. To fix the problem you must clear the defrost drain. It is located beneith the evaporator coils. When the frost on those coils melt it turns to water. Remove the freezer access panel, and clean out the drain. Use some hot water or a shop vac.
Jan 12, 2009 | Refrigerators
Water leaking from ceiling of frig, no ice forming.
pat,this is tom.if your box temps are fine.then you have a blocked defrost drain.[if temps bad ,will condensate in fresh food because warm temps]couple ways one is to shut box down eight hours other is to remove the back frezer panel and clean out all that ice and clear drain.you can use blow dry to melt ice[watch water and electricty do mix at all,be carefil]once ice gone use weed eater line with nott in one end to push threw and come out ouher end and cleanin His name,tom
Jan 02, 2009 | Freezers
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
271 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
