Question about Miele Dryers
My miele t230c has a fault - it starts to dry then the "machine iron" light flashes and the cycle stops
SOURCE: Not drying
I had the same problem with my dryer.
MAKE SURE THAT POWER IS OFF AND PLUG IS UNPLAGED AT WALL
On the back of the dryer there is a white metal cover in the centre with two philips screws. Once removed you will see metal box which has elements like a toaster built inside it.
You will see two sensors sticking out of top of metal box. The left one is the sensor for safety cut out in event of the dryer sensor on the right stopping working and letting the dryer overheat.
If you disconnect the left sensor 2 crimps and put multimeter on the left sensor two pins and if the meter beeps on continuety the sensor is ok. but if no beep the sensor is bad.
If sensor bad you can tempary bypass the sensor by joining the two cables together and try running dryer on a program and if heats up you know that you need to get new sensor.
WARNING! IF YOU LEAVE THE LEFT SAFETY SENSOR BYPASSED IF THE RIGHT HAND SIDE SENSOR MALFUNCTIONS THE TEMPERATURE WILL RISE AND CAUSE SERIOUS DAMAGE OR FIRE. THE PURPOSE OF THE RIGHT HAND SENSOR IS WHEN THE DRYER HEATS UP TO HEAT IT CUTS OUT AND WHEN DROPS DOWN IT HEATS UP AGAIN SAME AS AN OVEN.
You can maybe buy sensor from a meile dealer or RS COMPONENTS have the same sensor for £3.35 each.
NOTE: I ACCEPT NO RESPONSIBILY FOR DAMAGE OR INJURY IN MY ADVICE FOR REPAIR OF DRYER.
Posted on Dec 12, 2008
  • 66 Answers
SOURCE: Problem with Miele Touchtronic T 9800 Dryer end indicator
You've most likely got a bad control board. You'll have to install a new one which can be a bit expensive but cheaper than a new machine by far. I recommend getting a service tech to replace it for you however if your handy you could replace it yourself. Just get the new control board from an appliance parts store, they should be able to look up which board you need as long as you bring them the model number.
Posted on Dec 15, 2009
  • 70 Answers
SOURCE: Miele T230C do no start
If start LED does not blink, most likely fault is your door lock.
Posted on Mar 28, 2010
  • 2468 Answers
SOURCE: Miele Novotronic T230C Electric Dryer Dryer is
first check for 240 volts input on the unit if its electrically heated if you have no heat at all,then if you have some heat but it cycles on and off heat wise and the heat isn't as high as it should be,it can be the high-limit thermostat,the cycling thermostat both on the element housing,or it can also be a thermistor sensor on the blower housing if it only acts up on certain settings,you can bypass the 2 components on the element by jumping the wires on the components carefully together temporarily to see if this helps the heating cycle,but not the thermistor,as this is a resistance sensor
Posted on Oct 05, 2010
TheMobilian
  • 8220 Answers
SOURCE: miele novotronic t230c condesner dryer rotates,
Probably a clogged condenser. With the condenser full of lint the dryers ability to work right is greatly diminished. Remove and clean the condenser.
These are relatively new in my area. I have posted Miele service manuals for washer and dryer HERE.
Posted on Nov 03, 2010
Just purchased 2nd hand Miele novotronic w310. Does machine automatically stop? Cycle ends, anti crease light on and machine just tumbles clothes makes odd noise, then tumbles again. Is the normal?
NORMALLY WHEN A DRYER COMPLETES IT'S DRYING TIME IT WILL GO THROUGH A COOLING DOWN CYCLE,
DRYER WILL START TURNING WITH FAN ON ONLY FOR A FEW SECONDS THEN STOP, AFTER A SHORT PERIOD IT WILL DO IT AGAIN AND AGAIN UNTIL UNIT HAS COOLED DOWN, HOPE THIS IS WHAT YOU ARE EXPERIENCING
GOOD LUCK
Sep 22, 2016 | Miele Washing Machines
MIELE W412 PREWASH INDICATOR FLASHING
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
Premier w500 the rinse light flashes rapidly and the cycle stops. Any thoughts?
Hi just wondering if you got your problem with your miele sorted out yet as mine has done the exact same thing. Rinse light flashing rapidly and cycle stoped. Have cleaned the filter and re started but no joy.Any luck?
Jan 09, 2011 | Miele Novotronic Premier 500 Front Load...
Jan 04, 2010 | Miele Novotronic T230C Electric Dryer
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Problem during drying cycle
THERE COULD BE TWO POSSIBLE TYPE OF FAULTS FIRST IT COULD BE A FAULTY HEATER THERMOSAT.SECOND THE HEATER HOUSING UNIT MAY NEED TO BE CLEAN OR THE TIMER IS FAULTY
Apr 05, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
