Question about Refrigerators
Icemaker does not make ice. Appears no water is getting to maker.
Icemaker not producing ice. Does not seem to be getting water, although chilled water dispenses from door.
  • Anonymous May 21, 2009
    ice maker not producing ice but water still dipenses properly.
  • mayooman Jun 09, 2009
    Thanks Joe!
  • 10,865 Answers
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on May 20, 2009
  • Joe Hogan Jun 10, 2009
    You are so welcome. Get back any time if you need help again. take care.
The icemaker is not producing ice. Water is not going into the icemaker to produce the ice.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 30, 2010 | LG LSC26905 Side by Side Refrigerator
Manually add water?
Put 2 cups of water into the maker.
Jun 20, 2010 | GE Monogram ZDI15C Automatic Icemaker
Ice maker is on but is not producing ice
The ice maker is probably not getting water. Have you heard the water valve click on and off to allow water to flow to the ice maker? If you get chilled water from the fridge, the ice maker's water valve will probably sound very similar to when you dispense chilled water. Try the water to listen for it. Then, listen for it over the course of an hour or so to determine if the ice maker is doing the same thing. If you hear it - then there may be a blockage in the line or filter.
If you don't have provisions to get chilled water from your fridge (ice only) or notice that you can't get water from your fridge any more: Make sure the water supply is on and.. that supply line isn't kinked or got crushed when the fridge was pushed back into position. This is a pretty common occurrence. If you don't hear any water valve clicking, the valve itself may have failed or there may be a problem with the electrical circuit. Hopefully, you won't have to got beyond this, but if so - let us know.
May 24, 2010 | GE GSS25LGM Side by Side Refrigerator
Icemaker does not work
if the ice maker cycles but is not getting water check the water supply valve that supplies the water to the machine it split and sends water to the door and the ice maker that side of the valve that goes to the ice maker could be bad you can test it with a 120 volt line cord plugged in the wall plug to that side of the water valve if it works with the hose disconnected it may be a blockage or frozen line to the ice maker
Apr 09, 2010 | Refrigerators
Ice maker in refridgerator freezer won't make ice. It seems as if the water is going up into the freezer but no Ice is being produced. The ice tray has frozen ice in it, but it will not dump it in the ice...
Sometimes icemakers get all frozen up, such that the motor cannot turn to eject the ice. Also, in some cases the water supply line freezes up, although that does not sound like your problem.
Try leaving the freezer open to defrost it manually and see if it starts working by itself. Also, the icemaker motors can and do fail. In some cases you smell an acrid burning smell when the motor fails.
Oct 16, 2009 | Kenmore 50522 / 50524 Side by Side...
Ice maker not producing ice. Tried everything in the Troubleshooting section of Users Manual. Replaced water filter. The front water dispenser is working.
the most likely thing would be a bad water valve.try to reset the ice maker and watch to see if the tray fills up the fill tube could also be blocked with frozen water.the last thing is simply a bad ice maker.
Sep 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Chilled Water supplycomes out very slow. Ice maker
Its time for a new filter, the water filter will be in the upper right hand section of the freshfood section, or in the kickplate at the bottom
Jul 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
GE Profile TFT25 PR. Ice maker quit producing
Had the same problem. Replace the water filter and is should begin making ice again.
Mar 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
Amana ice-maker
Very curious. When you say the tube to the ice maker was disconnected I am unsure as to which tube you are refering to. However hopefully a few pointers might help a damsel. Most units have the water supply enter into the cabinet through a two way water solenoid valve (i.e. one for chilled water one for the ice maker). It then normally enters the top of the freezer section for the ice maker. It then drops down inside the freezer section to the icemaker module. Therefore the only control over the water for the icemaker is the solenoid valve which is controlled by the icemaker "module". A trick is to switch the control at the solenoid valve so that you can use the chilled water dispenser to check if the water valve for the icemaker is working. If it is then you probably have a problem with the icemaker module or the temperature in the freezer section (which you would probably have noticed if that was the case). If you have a problem with the module then you normally have to replace the module as they dont like supplying spares for modules.
Anyway hope this is of some help and good luck.
ps model is normally near the salad drawer or top of the fridge section dependent on brand.
Feb 08, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Icemaker will not was dispense ice
My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
Nov 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
478 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
