Tuning tv channels - Televison & Video
Programming my tv with a remote
you can program the channel manually, just press the menu button in the tv panel. select preset and then manual fine tuning to tuned every channel you want to watch and then save it.to make a manual fine tuning, press manual then select channel you want to tuned and then press vol. up/down button to search right frequency channel.do this process in every channel you want to tuned. hope this can help.
Sep 15, 2012 | Haier HL24XLE2 LCD TV
Trying to tune tv to channel 3,but it doesnt want to stop on 3. goes all around the dial will stop on 2or4 but not on3.
Did you try to manual tune/search the channel? If you are using the autosearch/tune feature and the signal is not strong it will simply skip the channel. Find channel 3 with manual search and then save it. Good luck!
Dec 14, 2007 | Televison & Video
I can't receive the higher channels on my TV. ex. higer tha #70.
Check to see if the tuning mode is in Cable/ or TV...TV will only allow you to tune 69-70 channels and when in cable mode it will allow all channels to tune
Jan 03, 2011 | Televison & Video
How do I tune TV channels on my Sharp CX48G4 TV without a remote control? There is no tuning / settings panel on the TV itself which is very strange.
press the preset button on the front panel once then (TV should be on) the on the screen there should be words the likes of (Auto VHF 1 60.00mhz) now the Auto stands for auto tuning VHF stands for its frequency where its going to search the 1 stands for the channel where its going to start with 60.00mghz stands for the lowest signal to which its going to start now that you have understood all that just press the volume up button then it will automaticly locate all your working channels leave till it stops for when does it will start from channel 1 to which I believe that you be able to see the channel working so press the up button on the channel button to check the rest of your channels hope this will solve your problem!
Jun 01, 2009 | Televison & Video
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Technika tv lcd 19-907 tuning in to sky in bedroom.
Hi i had the same problem but i have sorted mine now. What i was doing wrong was i wasnt tuning in the analoge channels only the freeview digital ones. To do this you need to first turn your tv on. Then press the "source" button, this will bring up a little menu at the top left hand side. When this menu comes up press the "Programme +" button (the one that you use for changing channels near the volume button) press this until you get up to "TV", when T.V is highlighted just wait 3 secs and it will switch over. You will probably get a blue screen with a no signal message (you are now on analogue) when you get this blue screen press the "tune" button. It will automatically start tuning in all of your channels, at first they will be fuzzy but as it works they will become clearer. Your sky channel will also be tuned in. When mine tuned in it didnt tune them in on the right numbers though, bbc2 was on number 1 etc. If you ever need to use a playstation or something it goes into the scart connection at the side of the t.v and you need to press "source" and go up to "scart". To get back onto the digital channels just press "dtv/dvd".
hope i helped!
Dec 14, 2008 | Televison & Video
Channel tuning
use your tv/video button to change inputs
Apr 20, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Tuning My Tv
If you've store the earlier channel, off the tv and on it again. Every should come back as normal.
Regards
alan
Mar 02, 2008 | Televison & Video
Tuning problem
Your TV is set to Antenna. You need to go into the menu and change it to Cable. Then do an autoprogram.
Jan 30, 2008 | Symphonic ST419E TV
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
Electro Med Services...
