Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
My calor gas heater has started buzzing
The flame is making a buzzing noise
Kampa Calor. Why isn't it lighting?
sounds like the line from the gas bottle is air locked .keep trying to light whle holding the button down longer
Feb 11, 2016 | Heating & Cooling
Portable calor gas heater ignition flame goes out when releasing no gas to heater
Clean out pilot could be too short to heat up thermocouple, try blowing it clean with a small tube
Dec 27, 2012 | Heating & Cooling
My Maytag Gas Dryer makes a loud buzzing noise when the ignighter and flame come on
thats a good sign the valves that those coils you replaced sit on are getting bad and you will sooner or later need a brand new gas valve
Oct 13, 2012 | Maytag Dryers
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 06, 2012 | Rheem Water Heaters
When gas wall heater lights a ball of flame comes
Lets get a tech in there to get it cleaned and the gas pressure checked.
Jan 18, 2010 | Off The Wall Heating & Cooling
I have a blueflame calor gas heater and the flame is mostly yellow
it sounds like the burner could do with cleaning bust in the burner
Jan 02, 2010 | Heating & Cooling
Maytag gas dryer noise when burner comes on
The noise you are describing is coming from the gas valve solenoid coil assembly. This is usually indicative of weak coil.
If this is a warranty situation, request a factory authorized certified technician to replace the solenoid assy. at no charge.
If you want to fix it yourself, be sure and ask us for instructions on replacing the part safely.
Thank you for contacting us at FIXYA.com
May 28, 2008 | Maytag HYG2460AWW Gas Dryer
Heating & Cooling Logo
64 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
T bone 1963
Paul Carew
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
