Question about Creda Ovens
Timer was set then stopped by me then oven went off I cant get it on again I have turned the cooker off then on I have tried to reset the cliock which just flashes
  • 4 Answers
SOURCE: ovens on cooker
DEPENDS ON THE MAKE AND MODEL EACH TIMER OPERATES DIFFERENTLY, BEST SOLUTION IF YOU DONT USE THE AUTO FUNCTION IS TO HAVE THE TIMER WIRED OUT SO OVEN COMES ON REGARDLESS IF THE TIMER IS SET OR NOT.
Posted on Feb 14, 2008
  • 3 Answers
SOURCE: electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Posted on Jan 15, 2009
  • 8 Answers
SOURCE: Electrolux oven won't come on
It appears that the "return to manual" button has to be reset
Posted on Sep 02, 2009
barkencoa
  • 3463 Answers
SOURCE: can not reset clock or timer, oven will not work
Try pressing the first 2 buttons on the left, and the last button on the right of the timer all at the same time.
It may differ to this depending on the actual model, but it is usually a combination of 2 or 3 buttons.
Hope this helps, if it does solve the prob, please feedback.
Thankyou.
Posted on Dec 21, 2009
SOURCE: Baumatic Oven - Setting the Clock/timer after power has been off.
Hi, You press the second and third button in together, hold them in and use the + or - buttons to set the time.
Posted on Jan 03, 2010
Bypass a faulty timer unit on a stoves 720ef cooker. . . . My partner tried this today on my cooker and now there is no power to the cooker at all!! Is there a chance he's managed to do the wr
I would suggest the wrong wires were cut off and joined. If the ground wire touches the power wire a fuse or circuit breaker will blow.. Before you do anything more make sure the curcuit breaker is not blown. If it is reset it and turn the cooker back on. If the breaker blows again then it is wired wrong.
Dec 16, 2014 | Stoves 720EF Electric Double Oven
Manual for tricity contessa cooker, double oven and grill with slow cooker button. Just brought this reconditioned cooker, but it hasnt got a manual and I need one. I can't get the oven to turn on, it...
i have a vey old tricity contesssa cooker(which i love!)
The rings are heating but the oven and grill have stopped working,any suggestions on how to fix please??
Oct 08, 2011 | Ovens
Lost handbook for cooker. Cant remember which
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Dec 13, 2009 | Stoves 720EF Electric Double Oven
Need to reset my whirlpool 2000+ cooker
Do you have a push button in the centre , between 2 dials and under display? If so, try pushing it twice then turn oven dial
Nov 14, 2009 | Whirlpool RBS275PD Electric Single Oven
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
Cant set cooker clock so cant use oven as a result
You will probably have to replace the cooker clock. Do any of the other parts work? This fortunately is not that expensive and you were blessed not to have more damage than this.
Jan 29, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Electric oven & grill not working no digital clock display
If there is a display on the clock and you cannot reset it to manual, then the oven will not work, if you cannot reset then you will probably need a new timer fitting.
They can be bypassed, but not recommended unless you know what you are doing..
If there is no display at all , then check to make sure you have supply to oven
Plz rate my solution.
Thanks.
Dec 16, 2008 | Neff U1661 Double circotherm super...
Electrolux EOG7330 gas cooker - electric timer fails?
Jul 18, 2008 | Electrolux EOG7330WN Gas Double Oven
Delonghi DFS901SS
have the same problem as you all. i myself removed the top of the hob to reveal a burnt out control switch . i have looked online for a replacemrnt , and it is £66 plus vat from delonghi but have found a cheaper one for £42, cant remember which site it was but type in cooker name and model on google and you will see it for yourself . good luck to you all, it seems like an easy fix
Mark
Oct 21, 2007 | Ovens
Ovens Logo
11 people viewed this question
Top Creda Ovens Experts
Craig Butler
Craig Butler
Pcm2048
Andrew Taylor
Andrew Taylor
Are you a Creda Oven Expert? Answer questions, earn points and help others
