Question about Refrigerators
Freezer not freezing
My fridge and freezer is not cooling
jumptrout51
  • 3361 Answers
SOURCE: freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Posted on Feb 28, 2009
  • 10865 Answers
SOURCE: frige light on not cooling,freezer fan working but not freezing
Hello there. Let me see if I can assist you.
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on May 27, 2009
  • 833 Answers
SOURCE: No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Posted on Nov 12, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Fridge side not cool and freezer side cooling like a fridge
Most likely a defrost problem. Are you sure your model is the model posted above your post? RS2630SH If not please let me know the correct model number. I have most of the manuals on the Samsung..............Sea Breeze
Posted on Jun 20, 2009
woodchuck789
  • 4070 Answers
SOURCE: the fridge is cold but the freezer won't freeze
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Posted on Jul 01, 2009
Hi I have a very old KIC fridge freezer the freezer is cold and works well the fridge is not icing up on the back board in the fridge everything going off in the fridge what could be causing this?
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Nov 01, 2011 | Refrigerators
Fridge won't cool but freezer working fine
Oct 31, 2011 | Refrigerators
I have A LG SXS Fridge. The Freezer is fine the fridge is not cold. I have read that the damper door might be closed. How do I find the damper door?
The damper is between the fridge and freezer section.
I have a Maytag Bottom Freezer that the freezer is frozen and the fridge is warm?
Oct 27, 2011 | Refrigerators
Fridge not cooling.
Oct 23, 2011 | Candy CPCA240FFK Bottom Freezer...
Fridge not cooling... Freezer is fine
Sep 12, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My fridge freeze is excessively freezing in the freezer compartment and not chilling in the fridge compartment Any help would be greatly apprieciated Brian
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Microwave Ovens
My Magicchef fridge is not cooling but freezer works perfect..How do i find the problem
Jul 28, 2011 | Magic Chef CTB1502AR Top Freezer...
Gss25xsrd ss GE fridge gets warm on the top (both fridge and freezer side) and freezes at the bottom. Ice completely melts and veggies in the drawers freeze too.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Refrigerators
Refrigerators Logo
237 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
