Question about Canon IMAGERUNNER 6570 Copier
Need to locate the waste toner container on a Canon ir 6800
I need to locate the waster toner container for a canon ir 6800.. Any ideas?
  • Canon Expert
  • 1,326 Answers
The waste toner bottle should be on the right side of the copier toward the rear of the copier. It is behind a pannel that is held in with 2 screws. Take the screw out & open the pannel & the bottel should be inside that opening it is a milky white container. Pull it out, it is rather large. When you dump out the toner make sure you have a plastic bag with No holes in it, it can be very messy if you are not carefull......Good Luck
Posted on May 21, 2009
Thanks a bunch been looking through manual but could not locate it.
Posted on Sep 03, 2009
Show me a picture of the waster toner on canon ir3035
It's in the front of the machine,abowe the paper casette.Part number for the waste toner box is FM2- 0303-000
Oct 08, 2014 | Canon iR3035 Copier
How to solve canon ir 3300 error code e0000190000
Neele, Error code E000019-0000 is a waste toner full , to get rid of this error, remove the waste toner bottle located left rear side of the machine,dispose of waste toner and clean the neck of the bottle because waste toner could obstruct the toner sensor beam. Switch off then on, OK to use.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread Canon IR 2200 Error E000019 0000
Canon ERROR 19 Waste Toner Tank
Jun 13, 2014 | Canon (6981A002AA) for imagerunner 2200,...
Erroro19
E019 0000 Waste toner full detection The waste toner full state was detected.Replace the drum unit.
0001Waster toner full detection sensor is faulty. . The waste toner full state was detected continuously for five or more seconds while the main motor was turning.
- Check the connector of the waster toner full sensor. - Replace the waste toner full sensor. - Replace the DC controller PCB.
Mar 10, 2011 | Canon iR 2016i Black and White Copier
Error code E019
E019
0001 Waste toner full detection
0002 Waster toner full detection sensor failure
you will have to replace the drum unit because it is full of waste toner.
Nov 14, 2010 | Canon iR 2016i Black and White Copier
I cannot find the location of the waste toner bottle.
On iR 2200, the waste toner container is located from left side of copier. To be precise, on left side are door with handle (wich is opend to reach paper in fixing assy or duplex), beneath this door ( left lower section from the door ) is small cover with one screw, when you remove it you will be able to see waste toner container. Its a plastic botlle, remove it clean it and dry it.
Feb 28, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Canon Copier 6025
The Waste Toner is located in the the drum unit it self. You need to remove the drum unit & on the top of the drum unit is a white or clear rectaular cap. You need to open it carefully and vac out the toner in side the unit. FYI if you are empting the waste toner the drum is just about worn out... Good Luck
May 18, 2009 | Canon NP 6551 Black and White Copier
A message is poping out saying replace the waste toner container.
I'm taking it that you have a IR-2270, not a IR-5570 correct??? The waste toner bottle is behind the front cover... It is in front of the drum unit. It is measured by the weight of the bottle, you just need to empty the bottle and you should be all set.... There is one screw in next to the toner bottle.... The other one is on the top left front corner of where the paper comes out. You have to push the front pannel to the left to remove the cover... Good Luck
Apr 14, 2009 | Canon imageRUNNER 5570 Copier
Toner waste container location
The waste toner is in the front, open front cover and the white bottle in the middle is the waste toner cartridge. Remove the black screw, and empty or replace the cartridge.
Mar 30, 2009 | Canon iRC3100 Printer
Canon IR 2800 waste toner container
hi: the toner waste bolltal is inside of the copier on the left side of the copie,it is inside the covers and needs to be empity by a technicen because also get drity and needs to be cleand.
Mar 31, 2008 | Office Equipment & Supplies
479 people viewed this question
old marine
old marine
