Question about RIM BlackBerry Pearl 8100
The pearl is not moving the curser
THe sensor for the pearl doesn't seem to picp up that it is being turned/spun
  • Anonymous May 21, 2009
    I have the same problem, the scroller ball is moving down but the arrow will not move and my light is out under the ball is it related?
  • 541 Answers
Please change the sensitivity, to change the sensitivity follow the below steps
  1. select option in the main menu
  2. select Screen Keyboard
  3. set the horizontal/vertical sensitivity as 100%
Posted on May 27, 2009
  • Avinash Raj
    Avinash Raj May 27, 2009
    go to options and go to screen/keyboard option and go to track ball.and change the vertical and horizontal sensitive and check.if it is physically damaged then u have to vist the nearest blackberry showroom
I have a older husqvarna 455 rancher chainsaw. How can i clean the fitting that allows oil to come from reservoir to pump?
To access the pick up pipe you need to remove the clutch and sprocket, the clutch is spun onto the crank with a left hand thread, it is fairly acceptable to jar it off using the combi screw driver placed into the cut a ways in the cltch shoes and strike with a suitable hammer until it spins off, once off you can pull the oil pump drive off, now remove the stainless steele plate once off the pump is held with one m4 allen self tapping screw, once removed the pick up picpe sits behind it.
Aug 01, 2017 | Husqvarna Garden
Touch pad stopped working. fix it?
Since it is a new computer, the fastest way to take of this issue, is to go to system restore and restore your notebook to a restore point prior to having this issue.
Tony
Feb 10, 2013 | Asus Notebooks 15.6" Intel B980 4GB 500G...
Engine temperature gauge low
I would suspect the thermostat first.
Aug 17, 2017 | 2002 Dodge Grand Caravan
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
My curser is stuck on my mini hp laptop. it seems to be locked up.
Hi.
The should be a a liitle light on the top left corner of the touchpad, double tap on that and it shoud re-enable. If that doesn't work hold down Fn and press the F9 key.
Good luck.
Jun 09, 2011 | Computers & Internet
Curser jumps all over screen when mouse moved
If you don'y use a mouse mat then your sensor (if you use a mouse with a censor) is picking up bumps, or changes in the surface it is moving over and turning it into jumps on your screen and using a mouse mat should solve this. If you use a mouse with a ball the take the ball out and give th rollers inside a good clean.
Mar 19, 2010 | HP Wireless Optical Mouse
Touchpad seems stuck. Can move curser, but cannot
Does it pop up? or you just can't click try hitting it really hard...
my right click is broken permanently but still pops up
Oct 25, 2009 | Sony VAIO FX215 Notebook
Pearl ball will not move up and down. Can it be
My blackberry does this all the time. I keep a supply of alcohol swabs available and rub it over the ball for about a minute and it always works. They seem to get dirty easily and need to be cleaned fairly often.
Jun 27, 2009 | RIM BlackBerry Pearl 8100
Curser on laptop frozen
Press the "Fn + F9" keys to enable and disable the touch pad at will.
best regards
Nov 18, 2008 | Toshiba Satellite A205-S4617 Notebook
RIM BlackBerry  Pearl  8100 Logo
425 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
