Question about BenQ Office Equipment & Supplies
Scan legal size documents flat scanner - BenQ Office Equipment & Supplies
3 Suggested Answers
SOURCE: Scanning legal size documents
Using SCAN feature of Paper Port software - (after clicking SCAN button ... select Define under Options section of the window ... the option to select paper size then exists). With harmony.
Posted on Apr 28, 2009
mohanchennai
  • 490 Answers
SOURCE: letter size document scans as legal size document
This is software setting issue. Just check your settings, if a 'default' button is available in the software, press it and then select your required settings. Some softwares dont accept the new settings unless the 'default' is pressed.
S. Mohan
Posted on Oct 18, 2009
Cannot scan legal size document with windows 7
Of course it can't . Since the maximum scan size is 8.5 x 11.7 inches it cannot scan a document that is 8.5 x 14 inches which is legal size. To do legal size you must either have a large-format scanner so the glass size is large enough, or have an all-in-one that has an auto-feeder. Those use a different scan bar from the feeder and can do legal documents.
Mar 21, 2015 | HP Deskjet 3050 Multifunction Printer
How do i scan a legal size document on hp officejet 6830
You will need to use the automatic document feeder and there should be an option in the scanner software settings to tell it you are scanning a legal document.
Jan 31, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
How do i scan a legal size document?
Your Lexmark scanner may not be able to scan legal size documents (8-1/2 x 14)
Sep 18, 2012 | Lexmark X6650 4-In-One Wireless InkJet...
Dell 1815dn will not scan legal size documents
I had exact same issue, could not scan in any size larger than Letter; changed Scan Default settings for paper size but made no difference. Based on dmf1984's suggestion I did same: went to Start -> Dell -> Dell Printers -> Dell Laser 1815dn -> Network Scan and changed Scan Paper size to Legal hit apply then tried scan again... problem solved92a90e38-52a9-4018-8666-d2da0be7f6f8.jpg
Feb 14, 2012 | Dell 1815dn All-In-One Laser Printer
Have MFC 5890CN Brother. How can I scan legal documents?
To scan legal documents you need to set the scanner to legal. GO to Start menu / all programs / brother / scanner utility and set the size to legal.
Thanks,
Pat
May 11, 2010 | Brother MFC-5890cn Color Flatbed...
Cannot scan legal size documents. The scan goes through but it will only scan the letter size portion of the document and drops the rest of the text.
You likely need to install the Brother Scanner Resolution Improvement Tool. The description of the download states:
"This tool will expand the maximum scanning resolution capability and allow you to scan legal size documents."
Here is a link for the Windows Vista download
Nov 06, 2009 | Brother MFC 8840D All-In-One Laser Printer
Letter size document scans as legal size document
S. Mohan
Oct 15, 2009 | HP Office Equipment & Supplies
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
Scanning Legal Sized Documents
1. From the MP Navigator screen, select "Scan with Scanner Driver" in lower left corner.
2. When in ScanGear MP, select the Advanced Mode tab
3. At Input Settings, select Document (ADF) for document type
4. Set paper size in next window
5. Click Scan button at bottom
May 01, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Jan 28, 2008 | Xerox DocuMate 262 Path-Through Scanner
13 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
