Question about Maytag Washing Machines
MAYTAG MHN30PN - 9kg Is this the best commercial/domestic front loader washer if so how much and where can we buy it if not - what should we be looking at and where can we but it (and price), etc We currently have a very old MAYTAG Neptune Front Load Washer (bought 1994 - 1996) with a metal door, that is giving us issues - we think it make be leaking as it trips our power on 2nd spin cycle so we are thinking of replacing it we also have the matching dryer (which is still working brilliantly
  • 1294 Answers
SOURCE: water leaking out front of maytag washer
Remove the top cover of the machine. Check to see if the three tubes going into the dispenser drawer hv not come loose. Tighten well.
Posted on Sep 11, 2007
  • 1122 Answers
SOURCE: washer machine maytag neptune front load
take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
Posted on Jul 12, 2008
  • 113 Answers
SOURCE: maytag neptune front loader washer has NF error code
Does it agitate and does the door lock light come on? Theres a panel on the back you can take off via 4 screws. Here you can check the belt and watch to see if it spins or moves at all. If the door lock light comes on, and you here the door click. Than chances are your motor control board is bad. Seen this many times. Im actually replacing one tomorrow on the exact washer.I believe the part # is 22004045. Heres a diagram. If the door doesnt lock than you need either a lock assy or a new computer for it. The computer is in the top panel where the timer is. If you look at it you should see a burnt resistor. If no burnt resistor than its more likely th lock assy. Ill try and find the part # for the lock and computer, and a digram. Hope this helps. Dave www.washermd.com
Posted on Dec 19, 2008
huuum
  • 750 Answers
SOURCE: Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Posted on Apr 03, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
Maytag 5000 series front load washer wont spin, F11 code
I got my Maytag 5000 in 2009. After about a year started having problems. Of course, I was told warranty wouldn't cover the problem. I googled several things, fixed some issues myself. But this washer has been a piece of junk after a year of use. Front loaders are far from cheap. It will be a long time, if ever, that I buy another Maytag appliance.
Mar 01, 2012 | Washing Machines
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
What is its capacity
Overall home/domestic washers have similar capacities:
Front loaders: between 15 and 20 pounds capacity.
Top loaders: between 10 and 12 pounds capacity.
The best way to determine if you are not overloading your washer is by loading your clothes in the washer making sure it is loosely full of clothes "do not push the load down" to make room for more.
Aug 30, 2009 | Whirlpool Washing Machines
How do you remove drum from outer casing and replace bearings
dissasemble front of machine undo rear pulley I suggest you buy a tool called the Tony tool which is made to install and install the bearings correctly
Feb 21, 2009 | Maytag MAH21PD Front Load Washer
Aquaris Hotpoint Wma 13
Dear grahamconnor,
ngfam1 here for you!
I am happy to be of assistance!
If the machine is 10 years old or more buy a new one!!
Look at speed Queen washers1 They are commercial and have the best warranty in the industry!
use the least water and wash 8 loads a week for 25 years or more! They start at about $549 for the top loader and 1299 for the front loader, BUT the front loader uses ONLY 13.9 GALLONS OF WATER!
The last washer i will buy! And everyone working in my applaince store has one!
If you decide on service!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF
Aug 26, 2008 | Hotpoint WMA13 Front Load Washer
Maytag Performa Washer
Whirlpool is good but Speed Queen is the best with the best warranty in the industry!
Tested to wash 8 loads a week for 25 years!
3 years parts and labor compared to all others with only 1 year! And 10 years for the transmission not 1 year like all the rest!
only 34 gallons of water used in the top loader and 13.9 gallons in the front loader.
I'm 53 and I'm not buying another washer again!
YES I SELL THEM AND EVERYONE WORKING IN MY STORE HAS ONE! There are plenty of more features!
Speed queen is used in laundry mats all over the world!
So now that I reallllly saved you, GIVE ME THE BEST RATING SCORE HERE AT FIXYA!!
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jun 17, 2008 | Maytag Performa PAV2200
Front loading washing machines
not really front loaders have top loaders beat all the way but stay away from admiral and maytag .a front loader will wash your clothes using the soap that your top load failed to get out if i may suggest buy a frigidaire with a mechanical timer not electronic control more junk on them more to fail the best combo in my mind is a frigidaire front loader and whirlpool dryer front loaders use 2/3 less water 2/3 less soap and will get your clothes twice as clean they have no transmissions and are direct drive the most common promblems with them is having to clean out the pumps where people leave stuff in their pockets also you need to buy soap thats for front loaders its called high effincey or he soap and they will get your clothes make sure you read the installation guide and remove ALL the shipping braces
Mar 18, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
65 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
